Site Support If something isn't working or you have a suggestion ( a nice one !! ) let us know here. |
I did search, but obviously not in the right spot. I think some of us (well me anyway) would benefit from some clarification.
(And this is intended as a question for the Admin Team, not a discussion.) Which of the following is considered inappropriate. a) Using a word that I KNOW will be replaced by the filter. Eg “**** off” when I know it will be replaced with “****.” b) An adaptation of the word (that may or may not be caught by the filter.) eg ****, Fekking, Effing, *****. c) Abbreviations of common swearing phrases. Eg FFS, FMD. d) Using special characters to replace part of the word. Eg “F@#%” e) Replacing all of the word. Eg “%@!& off.” f) A word such as “horseshit,” which I actually thought would be truncated as “horse****” but apparently isn’t caught by the filter.
Time to Make the Hippies Cry Again |
meh.
![]() Join Date: Jul 2010
I'd probably suggest PM'ing a Moderator who can send your enquiry the right way...?
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
Chairman & Administrator
The question is of general value so I will answer it.
a) Using a word that I KNOW will be replaced by the filter. Eg “**** off” when I know it will be replaced with “****.” Is acceptable - the offence is avoiding the filter not using the * symbols. b) An adaptation of the word (that may or may not be caught by the filter.) eg ****, Fekking, Effing, *****. Not acceptable - this is avoidance c) Abbreviations of common swearing phrases. Eg FFS, FMD. Marginally acceptable d) Using special characters to replace part of the word. Eg “F@#%” Pointless really but that will depend on the mod as there are no clear rules around it. If it looks too much like the word then it is likely to get pinged. e) Replacing all of the word. Eg “%@!& off.” Equally pointless - same scenario as above really. f) A word such as “horseshit,” which I actually thought would be truncated as “horse****” but apparently isn’t caught by the filter. If the filter didn't get a full and correctly spelt word then that is something we need to remedy so it shouldn't incur a penalty. I trust this is clear.
Observatio Facta Rotae
I would have thought the easy way around this is simply not to swear at all, you should be able to get your point across without using it but if you really feel the need why not just use a suitable smiley
If FFS is marginal and can result in accruing points or a temporary ban, then why is this allowed?
wow, that's pretty sad.
I'm old and I fell
I got an infringement for typing the letter F followed by three asterisks. Does that count as something that shouldn't incur a penalty or was I out of line? Happy to accept the penalty and I haven't offended again as now I know that it is allegedly against the forum rules (which I didn't know beforehand), but for my own curiosity was I wrong to write that?
BF2 XR6 turbo 82lb injectors, Walbro fuel pump, bigger cooler, Plazmaman piping, SS Growler, tune, ZF tune, Crow valve springs so far. Ozracing coilovers, Pedders sway bars front and rear. 315rwkw |
#9 | |||
Previously there was just a broad view and it was up to mods to make their own call. My view, under the current guidelines, is that the scenario you draw would still incur a penalty as it is clear what the intent was. Cheers Russ
It probably is - but you chose to call it out and it is quite obviously a conflict with the current interpretation of a breach so there isn't much choice is there?
There's an old saying about never asking a question you don't already know or want to hear the answer to... it should have applied in this instance. Russ
15 users like this post: |
335 - STILL THE BOSS ...
I will also add though ...... in most cases its the way the words are used. If it is directed at someone else and in many cases it is, the problem comes down to being disrespectful or argumentative rather than just the words by themselves. WTF or FFS while everyone knows what it is, it will come down to how it is used towards someone else or just used in general chat. This is at the Mods discretion as said above.
I just type the way I would say it and if the computer picks up something that shouldn't be said, then so be it. To circumnavigate the swear filter because you know it cannot be typed is cause for concern. If anyone needs to swear, there are plenty of other sites to go off till everyones little heart is content. Cannot see the point when it involves the written word on a forum.
'73 Landau - 10.82 @ 131mph '11 FG GT335 - 12.43 @ 116mph '95 XG ute - 3 minutes, 21.14 @ 64mph 101,436 MEMBERS ......... 101,436 OPINIONS ..... What could possibly go wrong! Clevo Mafia [SIGPIC][/SIGPIC] |
Driver Returns On Foot
So that's what SFA stands for.....
#13 | ||
Russ, you obviously missed the point. It's a sad day when a forum is so heavily censored that it's gone beyond the normal realms of normal TV shows.
I can listen to an ABC radio station and be exposed to more swearing. |
#14 | ||
Awesome
Location: In my own little world..Everyone here knows me :)
At the end of the day, this is a FAMILY forum. If you want to swear, as others have said, there are other places on the interwebz where you can let rip to your hearts content.
I, for one, swear like it is going out of fashion but not around people who do not like it out of respect for them. On this forum and many others I am a member of, I don't see the point in it. In my opinion, you can get your point of view across in a post without swearing.
9 users like this post: |
#15 | ||||
Big Member
![]() Join Date: Dec 2009
Yes thank you Dazz for bringing this up. Now instead of having a marginal use of this Abreviation, we now have a crackdown. ![]() No, we dont have to swear, but sometimes, in context it is relevant to show frustration & confusion. I mean we even have a smiley that shows WTF. Or we did. I just tried looking for it to demonstrate. He seems to have been banished now. For instance I am about to notate in my build thread that I just changed the Starter motor in my car 3 hrs ago. 5ks from work the Alternator light came on (35ks from home). That means either the alternator or battery just carked it after I have had the car off the road for over a week waiting for a new starter. Seriously, WTF?? I think in that context it is OK, as a Smiley doesnt really convey the real-life frustration that you read "in your head" when reading a post, but reading WTF does.
The Scarlet Fairlane: 94 5.Slow Litre NC II Fairlane 488800kms & Climbing Rollin' on genuine ELGT wheels. K&N Filter /////Alpine Sound. EBGT Momo Woodgrain Steering Wheel The Scarlet Fairlane Build Thread Project "White Knight" 93 ED XR6 ROH Alloys Momo wheel Cruise Sunroof Premo Sound Manual HO Goodies PWK Build Thread 1990 Yamaha FZR 250: 59000ks & climbing. New fairing, old tank, my angry mosquito in a coffee tin! 14.977 1/4mile. ![]() |
#16 | ||
Either have rules in black and white for everyone to follow or only have one moderator so rules can't be manipulated by them.
What is the definition of a 'family forum'? |
#17 | ||
Afterburner + skids =
Oh man, just leave it!
#18 | |||
The one moderator suggestion is ludicrous given the post volumes here. My definition has always been - A member should be able to sit with their (reading age) son or daughter without fear of content being presented that could be considered offensive to them. Russ
23 users like this post: |
#19 | ||
AFF Whore
I try and use the 'wife' test... if its something she would scold me for saying in front of the kids its a no go.
#20 | |||
Funnily enough, I was on hold to one of my suppliers a multinational corporation turning over hundreds of millions a year. Whilst on hold the S bomb was dropped in some form of advert...Made me think of this thread. So in reality, this forum is like a 'G minus' rating where any perceived offensive language is banned regardless if it's abbreviated or self censored? General (G) G – suitable for everyone. The content is very mild in impact. The G classification is suitable for everyone. G products may contain classifiable elements such as language and themes that are very mild in impact. However, some G-classified films or computer games may contain content that is not of interest to children. |
#21 | ||
Half brain dead already
We care about this because? You really need to drop it. They have spoken, just leave it
"My Shockwave Baby" Running tuned at 191.3rwkw with 475nm Torque Pacemaker PH4490 + Hiflo Pacemaker cat/catpipe + Xforce 2.5' catback into dual pipes after Diff. FG Manifold + Herrod airbox + 20% underdrive +Hi flow thermostat + 26mm radiator and Weapon X coils! Now rolling on staggered Matte black Lesnso D1R's NOW MANUAL! Shockwave Blue!
More to come Now the proud owner of a '97 NL Fairlane |
2 users like this post: |
#22 | ||
Cannot see the issue either? I must be missing something very ******* important! Just type ******* **** till your hearts content and if the computer thinks its not appropriate, then it will replace it. Why is it a ******* problem? Blame the ******* computer
#23 | ||||
I have kids almost 1 yr old 5, 8 and an 11 yr olds there was a pic posted earlier today that my 11 yr old asked me about as she was sitting next to me when I opened the thread now if you cantell me a good way to discribe what the blue dildo on a bike seat pole is please help meout I dont need to have to explain that sort of thing to her when this is meant to bea car forum not filled with those images and language that would be a better fit in a ******* bar my 2c worth Quote:
sorry for the rant here but thats how i feel Jason
no longer have a ford but a ford man at heart R.I.P 98 EL MAY YOU HAVE A GOOD LIFE IN FALCON HEAVEN [SIGPIC][/SIGPIC]
#24 | |||
You have to bring out your other personality when you log into this forum lol. |
#25 | |||
![]() ![]() ![]() ![]() Why is it so hard to type how ever you want to ******* say and let the computer do the work? Everyone still gets the message without reading absolute rubbish on ever second post like you do on some of the other kiddie forums. It really really isn't that hard? Say want ever you want and let the computer do the editing. It comes out the same!
#26 | |||
#27 | ||
I checked ....... those had nothing to do with swearing.
#28 | ||
Thanks Russell.
As I said, this wasn’t mean to be a debate, I just think clarity is a good thing. At the end of the day I think we are all intelligent enough to abide by whatever rules there are. It’s not as if we’re being pinged for spoken words that just slip out. I think we are all accustomed to moderating our language depending on setting, and given the goal to be a family friendly forum I will take that on board. It’s not hard provided we know the rules.
#29 | ||
#30 | ||
Lame ?
There is a process we can follow if we feel hard done by from a moderator matey... and if that is still your first world issue then there are other forums that will let you swear /post links and abuse others to your hearts content !! Your choice whether you log on here or not ... no one is twisting your arm ![]() |
10 users like this post: |
