Old 29-12-2005, 05:27 PM   #1
snozzau
Default AU3 Recalls
Guys,
Where there any safety or service recalls for AU3 XR6s.
Just bought the car and arent quite sure where I'm up to.
Thanks,
Scott
snozzau is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2005, 05:42 PM   #2
Racecraft
they call me Tibbo
Racecraft's Avatar
there was one on all the AU series 3's .. THe rack studs needed a blob of weld on them
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2005, 06:25 PM   #3
Dark Horse
_Oo===oO_
Dark Horse's Avatar
Errr I don't think so - none of the AUIII's, or for that matter most of the Late Edition AUII's were affected. The issue was corrected in a running change in the production of these cars.
I've had my AUIII XR6 since new and haven't received any correspondence concerning recalls.
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2005, 06:29 PM   #4
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Yeah there were no recall's for the AU III.
Old 29-12-2005, 06:33 PM   #5
Racecraft
they call me Tibbo
Racecraft's Avatar
my bad must of been the series 2 then,, :(
Old 29-12-2005, 07:12 PM   #6
galaxy xr8
Giddy up.
galaxy xr8's Avatar
It was only a majority off vehicle's affected between a couple off month's, not all AU II's were affected, but Ford can tell you the dates off the affected vehicle's.
Old 29-12-2005, 07:18 PM   #7
parawolf
beep beep
For some reason Jan - May 2001 AUII comes to memory... not sure why...
Nothing to see here, move along, move along...
parawolf is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2005, 07:58 PM   #8
Mechan1k
Mechan1k's Avatar
There's a recalls site out there with all the details.
Lucky my AUII is an October 2001 build.
Old 29-12-2005, 08:54 PM   #9
Lukeyson
Right out sideways
Lukeyson's Avatar
My sedan and ute got the steering rack recal, sedan built march 01 and the ute october 01
2010 FG XR50 Turbo | 2007 FPV BFII GT, BOSS 302
Lukeyson is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2005, 08:58 PM   #10
noboss
Your Ford dealer will be able to tell you if there are any outstanding recalls for your car.
noboss is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2005, 09:28 PM   #11
Falcon Freak
Falcon Freak's Avatar
Originally Posted by snozzau
Guys,
Thanks,
Scott
If you want to know if your car was involved in any recalls then visit:
Government web-site listing ALL product recalls
If you want to know if there were any campaign items for your model then you will need to speak to your Ford dealer.
FF
Falcon Freak is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2005, 07:31 AM   #12
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Can I ask what was up with this recall?
It may explain something to me...
EDIT MKII - Tibbo explained it. I don't get that, it's all good.
Carless
TheSneakiness is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2005, 07:34 AM   #13
Racecraft
they call me Tibbo
Racecraft's Avatar
the studs the hold and locate the rack onto the alumium cross member can work loose, You get a clicking sound when you turn the wheels at low speed. Thats the rack moving :(
Old 30-12-2005, 07:52 AM   #14
buickman
buickman
buickman's Avatar
S1 & early S2 were affected. I would worry more about buying a car thats had a hard front hit & not being repaired right. On the drivers inside body frame a metal tag on the repaired date should bee there if it has been done
buickman is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2005, 01:19 PM   #15
richo77
richo77's Avatar
My Feb 02 XR8 has a field service campaign sticker completed in 4/3/03 number RCMC242C. Anyone know what this was about??
richo77 is offline   Reply With Quote Multi-Quote with this Post
Old 30-12-2005, 04:21 PM   #16
Whoosha
AU DIE HARD
Whoosha's Avatar
Guys,
Thanks,
Scott
Number 2 sons Au111 sr had rack problem came loose + popped a seal , wrong thermosat fitted, + split radiator ( pretty comon with alluminium )
All fixed under warranty no hasells
If you got a freindly Ford dealer get them to run your vin. or sido. for you and they can tell whats be done at any Ford dealership............ :eclipsee_
Whoosha
Originally Posted by Riksta
Old 01-01-2006, 10:53 PM   #17
XR6HP
Senior 3FB Navigator
XR6HP's Avatar
I had a non-critical recall done on my AUII XR6HP (09/01 Build) last service - on the service sheet it says: 'Vehicles 2B Crossmember RH Steering Rack Mounting Stud'
Maybe this will be of assistance to you...
XR6HP is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2006, 03:06 AM   #18
5 FTR 5
Made the 300 :0)
5 FTR 5's Avatar
srcc246 a/b/c/ was about the loss of front brakes somethink to do with the ABS loosing fluid under heavy braking,not sure if its somethink to do with this or another prob
New Owner of a fiesta ST
5 FTR 5 is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2006, 07:52 AM   #19
Tri Power 289
Back in the Game!
Tri Power 289's Avatar
I know there was a recall No RCMC252B which was a cooling system upgrade for all AU series I/II/III.
All they did was squash down the top row of the A/C condenser to allow more airflow to the top of the radiator and they also modified the thermostat.
Look to see if thats been done. (It was usually a pretty messy job!)
2016 Focus RS MK3
XHII XR8 Falcon Ute S/C 5.0 Manual
'66 Mustang coupe 289 Auto
70 Mustang Mach1 351 4V/Shaker Auto
Previous forum rides:
XH Falcon Ute 4.0 Auto
BF XR8 5.4 Manual
'88 60 Series Landcruiser Turbo Diesel.
Komatsu 830E Haul Pac- 2500hp, 165tonnes.
AUIII XR6 HP: Prepared by Aussie Car Enhancements & Custom Tuned by Blue Power to a record setting 14.22@96mph.
BA Fairmont Ghia 5.4 3V :Unfinished business.
Tri Power 289 is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2006, 09:55 AM   #20
cArSiK
Here Is the official Recall noice issued:
Ford AU Series I and AU Series II Falcon Model Vehicles (Campaign SRCC300)
Date: 18/06/2004
Supplier Name: Ford Motor Company of Australia Limited
Product Make: Ford
Product Model: AU Series I, AU Series II Falcon Model Vehicles
Model Years From: 1 June 1998 to 22 May 2001
Consequences: Deterioration or loss of steering control.
Campaign Number: SRCC300
VIN Range: [no data entered]
Serial Range: [no data entered]
Product Info: Ford AU Series I and AU Series II Falcon Forte, Futura, Fairmont and Fairmont Ghia, XR variants, Fairlane, LTD, Utes and FTE Vehicles built from 1 June 1998 to 22 May 2001 inclusive.
Defect Details: There is the possibility that inappropriate servicing of the steering rack retaining hardware may affect the integrity of the steering rack mounting stud. Overtightening of the steering rack mounting hardware may degrade the thread locking compound on th
Consumer action: Registered owners will be contacted by mail. For further information, contact any authorised Ford Dealer or Ford's Customer Relationship Centre on toll free 13 36 73.
cArSiK is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2006, 07:14 PM   #21
HLC
Audi S3
my car is a 10/2000 AU2 and it has a couple of recall stickers on it. not sure what for though.
HLC is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2006, 01:04 PM   #22
DJM83
Barra Turbo > V8
DJM83's Avatar
yeah mine is a 06/10 00 model and has had the steering rack recall
-2011 XR6 Turbo Ute - Lux Pack - M6
-2022 Hyundai Tucson Highlander Diesel N Line
