Old 07-05-2013, 10:51 PM   #1
Robbo95
Default Mid-engined falcon
Thought of this tonight. A mid-engined falcon .Someone should make one. Put a v12 in it. It would be so much more balanced and just great. Whats every one think?
Robbo95 is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2013, 10:55 PM   #2
jpblue1000
jpblue1000's Avatar
Default Re: Mid-engined falcon
would be an abomination with everything ruined. mid engined cars are designed that way not modified that way. there would be nowhere to sit and would understeer like a shopping trolley, wouldnt suit the bodyshape nor do an engine justice.
I say go for it, I love the idea...
JP
jpblue1000 is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2013, 11:28 PM   #3
FalconXV
FalconXV's Avatar
A ute would be ideal to start with, maybe you could fit a dry sumped I6 behind the cabin. Low enough to still have some semblance of a tray, straight into a transaxle, IRS.
I'm pretty sure there's a blue VE ute with a big block in the tray.
FalconXV is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2013, 11:33 PM   #4
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Intriguing, but highly disturbing.
Old 08-05-2013, 12:09 AM   #5
MattsDisturbed
Bseries
MattsDisturbed's Avatar
There is! Doesn't do much but wheel stands and flame jobs though.
His: 2003 BA Fairmont in Arctic White/Mercury Silver
Hers: 1999 AU Forte in Amaretto
Check it out:
http://fordforums.com.au/showthread.php?t=11336211
MattsDisturbed is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2013, 12:56 AM   #6
mik
mik's Avatar
Cool, it has a spare engine in the back !
Old 08-05-2013, 01:17 AM   #7
FGX-351
Supercharged Mang-mobile
FGX-351's Avatar
With all this talk of V12 Falcons, some might be led to believe a GTHO is in the pipeline! :P
09/00 VX HSV XU6 Build #0001 of 0171
http://fordforums.com.au/showthread....09#post5571209
-- Best E/T: |14.982 @92.12mph | R/T:0.013 | 60' 2.213| 330: 6.283 | 1/8: 9.624 @ 73.17mph | 1000: 12.529 | 25Deg, N/A Hum, 1010mb | Willowbank Raceway 7/12/16
Tickford EL Falcon XR6 RIP
-- Factory Manual
-- Best E/T: |14.991 @ 92.71mph | R/T: 0.607 | 60': 2.215 | 660': 9.665 |13Deg, 86%H, 1024mb, 184RA @ Willowbank Raceway
FGX-351 is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2013, 05:40 AM   #8
jpd80
jpd80's Avatar
A little research would show people why mid engined set up is reserved for two seater sports cars only.
The position of the engine forward of the front wheels precludes the use of a rear seat and a suitable Ute tray.
jpd80 is online now   Reply With Quote Multi-Quote with this Post
Old 08-05-2013, 07:20 AM   #9
Nikked
Oo\===/oO
Nikked's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Long time member, loves Fords, sensible contributor and does some good and interesting posts.
JP
Do what they did with the '69 mustang in America...
Drop the body over a GT40 chassis.
I want to do it with a XA Coupe...with a twin turbo Coyote!
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2013, 07:22 AM   #10
Nikked
Oo\===/oO
Nikked's Avatar
\≡≡T≡≡/
Old 08-05-2013, 11:06 AM   #11
jpblue1000
jpblue1000's Avatar
now add the rear doors and high rear roofline and see how it looks.
Arguably the mustang is adding a mustang to a Gt40 chassis not mid mounting an engine in the middle of a falcon.
Id also say the ute is a rear mount not mid.
JP
Old 08-05-2013, 11:31 AM   #12
strobe
If that ute is mid mounted, what do you have to do to be rear mounted? Have your engine in a trailer?
strobe is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2013, 12:53 PM   #13
Cobramad
Cobramad's Avatar
Needs to be at least a 7x5 trailer for an engine that big!
Cobramad is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2013, 01:05 PM   #14
mash again
Have had a stock BA 6 on the race scales with driver and 40l fuel and was very suprised at how well balanced it is for a street car. Hope to get the balance that good with all the weight removed and redistributed.
mash again is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2013, 01:07 PM   #15
MAD
Petro-sexual
MAD's Avatar
What about just pushing the engine further back into the cabin like a sports sedan.
- The Story
Old 08-05-2013, 10:29 PM   #16
Moby Vic
Cynical Idealist
Moby Vic's Avatar
Putting a mid engine in a four-door sedan is tricky. It's easier to put a rear engine in one:
Your plastic pal who's fun to be with!
Moby Vic is offline   Reply With Quote Multi-Quote with this Post
Old 08-05-2013, 11:22 PM   #17
FPV GTHO
Technical Contributor: For members who share their technical expertise. - Issue reason: Sharing his knowledge of performance exhaust setups for the NA 6 cyc Barra Falcon from BA to FG.
Well Ferrari did a 2+2 Dino as well as the Mondial but it seems the idea is pretty forgettable. There doesn't seem to be any logical reason anymore to achieve 2 row seating with a mid engine when you can achieve similar weight balance with better engine placement and rear mounted transaxle.
FPV GTHO is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2013, 04:17 AM   #18
chevypower
chevypower's Avatar
TWD? (Trailer-wheel-drive)
chevypower is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2013, 04:05 PM   #19
Robbo95
No one needs a backseat. Just chuck it in there. And have a transparent firewall
Old 09-05-2013, 04:56 PM   #20
tweeked
N/A all the way
tweeked's Avatar
The only way you will get this with a Falcon is when you are driving in reverse
BA GT
5.88 litres of Modular Boss Powered Muscle
300++ RWKW N/A on 98 octane on any dyno, happy or sad, on any day, with any operator you choose - 12.39@115.5 full weight
tweeked is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2013, 06:47 PM   #21
Gaz
Got Ghia?
Gaz's Avatar
Well with the engine in the back you can chop the bonnet and make the tray in the front!
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2013, 07:20 PM   #22
Phil B
Clevo power!
Phil B's Avatar
I have thought previously that something like this would go nicely in a ute tray.
I doubt it would be very quick, but who cares when you have a 27 litre (1,650 cubes) V-12
Yup, each cylinder has more displacement than a riceburner
The beast: XB coupe, 302, manual all the way!
Fixing up thread
The purple monster, daily BA XR6 turbo.
Scale Lego Technic XB Coupe with working bits! Build thread
Phil B is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2013, 07:48 PM   #23
Crazy Dazz
What about a trayback ute with a flat engine mounted in front of the rear axle. Could probably squeeze a Testarossa flat 12 in there.
Or make ya own by whacking a couple of I6's together.
Making Whine from the Tears of Hippies
Old 09-05-2013, 07:55 PM   #24
fordman302
fordman302's Avatar
I recall watching a similar holden wheel stand ute doing a display at the v8's at sandown one year, it didnt brake late enough, front end bounced and it fell over in the grandstand at the end of the front straight, needless to say it wasnt the best handling machine, but overly amusing
fordman302 is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2013, 08:28 PM   #25
THABOSS
THABOSS's Avatar
Always dreamt of doing this! If I ever won the lotto I would attempt to build a mid engine GT Coupe. using the FG styling.
THABOSS - 2008 FPV FG F6 - Serviced by McInerny Ford, Morley.
Mods: Herrod Cold Air Intake, K&N Filter , Boss Bonnet, XForce Cat Back.
Power: 341.5 RWKW (Tuned by Simon at Xtreme Ford Tuning)
Video of the XForce Exhaust
THABOSS is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2013, 08:43 PM   #26
ebxr8240
Performance moderator
ebxr8240's Avatar
Started a mid mount 289 Mk1 Cortina years ago as rally cross car..
They changed the RULES when nearly finished ..
I had V drive from boat with engine on sub frame in front of diff. No rear seats..
Daily driver GTE FG..
Old 09-05-2013, 08:57 PM   #27
Nikked
Oo\===/oO
Nikked's Avatar
huh?
here is one...
\≡≡T≡≡/
