Old 26-04-2013, 12:37 PM   #1
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Default "Capped" price servicing?
Just a quick question,
For those who take their car to a dealer to get their A and B services done:
Have you always been charged the full amount to the dollar that the site says is the 'most' you will pay under the program?
Or, have people been charged 'up to' the maximum amount? Ie, they did the work, used the consumables and when the invoice was broken down it came in under the maximum, so you were charged a lower amount reflecting the work done and parts used?
Cheers,
Jason
___________________________
Old 26-04-2013, 12:52 PM   #2
poppa smurf
poppa smurf's Avatar
Default Re: "Capped" price servicing?
quote for services prior to the job being done has never been the sum paid, always over
however there is always "extra's......coolant replacement, brake fluid replacement......just had my "B" service.....$490.....but all 4 brake replacement were in there as well
I dont worry too much about the initial "quote" just go into shock when I get the invoice
G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II...
may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon!
poppa smurf is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2013, 12:53 PM   #3
cobramania
FPV BFII GT Cobra No.249
cobramania's Avatar
My last capped price service for my FPV GT was in December last year. Going by the quote on the Ford web site, my capped price for a 30k service should be $385. Price I actually paid was $328.15 including a 1.5% credit card surcharge fee.
cobramania is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2013, 12:58 PM   #4
Yellow_Festiva
Where to next??
Thanks. What I meant was for just the service component. I understand that coolant / brakes etc are over and above the base cost.
If you got a B service with brakes done on each corner for $490 total that is bloody cheap!
Ford wanted something like $325 for rear pads only on my Focus...
Old 26-04-2013, 12:59 PM   #5
Yellow_Festiva
Where to next??
Thank you for your feedback.
Old 26-04-2013, 01:09 PM   #6
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Those prices on pads etc are about right, same thing when I was working at Honda, front pads were like $270-$300, wiper blades $88 for the front two etc.
With capped price servicing, does it just include the service? At Honda say we had to do a 40,000km service, it was a normal oil/filters change, plus valve clearance inspection and it was always around $800, but extra on top if you needed brake fluid top up etc and there was an extra sundries charge for stuff like brake cleaner usage and an oil disposal charge.
Old 26-04-2013, 01:12 PM   #7
poppa smurf
well it was supposed to be capped but the extras always push it over.....I didn't think the $490 was too bad but the $330 for my hood lining replacement was a bit rude
never mind ....pleasures of owning a motor vehicle I guess.......cant help you with a complete "capped price" service only......always had extras and never asked for a breakdown of parts or extras
oh! that price didnt include the car having to go back for an oil filter replacement (split and dropped oil everywhere) part of a bad batch apparently
Old 26-04-2013, 01:14 PM   #8
Yellow_Festiva
Where to next??
With capped price servicing, does it just include the service? At Honda say we had to do a 40,000km service, it was a normal oil/filters change, plus valve clearance inspection and it was always around $800, but extra on top if you needed brake fluid top up etc.
The services are priced as per what the logbook says is needed. Eg, a minor service "A" service, is generally a lube change and inspection. So that is what you are quoted for.
Then there is a *. This says, we will also need to do coolant every X years / km or brake fluid every X years / km and that is a surcharge.
So, the question is more for black and white servicing. Ie, all you need is a basic fluid change and inspection, the Capped price program says it will cost no more than $XYZ and I was charged $XYZ (like how cobramania replied).
Jason
Old 26-04-2013, 01:49 PM   #9
ryeman
Must be confusing if you supply some of the consumables
Wherenoshockjocksfly
Facts or the twitterverse, your choice!
M3SR+ .......MG ZS EV
ryeman is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2013, 01:52 PM   #10
Yellow_Festiva
Where to next??
Well, I guess in that case they won't use the capped price program. They will just charge you an hourly rate and whatever other bits and pieces they need to get the job done.
Then again, my last bill was broken down into parts, so I guess they can just omit what you provide. Which essentially brings it back to the first point.
Old 26-04-2013, 02:03 PM   #11
Silver Ghia
Silver Ghia's Avatar
Not really, with my service last month I supplied my own oil like I usually do, and was charged the capped service price minus what I thought was a reasonable cost for the oil which they otherwise would have supplied.
Without me asking, the service advisor pointed out the capped price on his capped price chart, to show that the amount charged was quite reasonable.
Silver Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2013, 02:14 PM   #12
superfly
Go the Hogster!
superfly's Avatar
For my 15K service I was charged the full $265 capped price fee. And that included the free road side assistance.
Nitro XR50 - the last brand new one in OZ
first registered Oct 2011.
superfly is offline   Reply With Quote Multi-Quote with this Post
Old 26-04-2013, 10:07 PM   #13
prydey
Rob
prydey's Avatar
my last 2 'A' services were $180. i think the capped price is around $250?? I also supply my own oil.
I'm guessing if everything was done by them, the 'capped price' would also be the 'minimum price', so regardless if it takes half an hour or 3 hours, the capped price is what they'll charge.
prydey is offline   Reply With Quote Multi-Quote with this Post
Old 27-04-2013, 07:31 AM   #14
buggerlugs
If it ain't broke........
Just had my young blokes 2011 SR5 Hilux Twin Cab 4WD serviced at Toyota. It was a 30k service and we were quoted $170.00 when booking it in. Cost $170.00 as per quote.......
Visitors welcome
Relatives by appointment only
buggerlugs is online now   Reply With Quote Multi-Quote with this Post
Old 27-04-2013, 11:26 AM   #15
Yellow_Festiva
Where to next??
Quite the opposite actually. The Capped price is the most you will be charged. Meaning it can be less, but not more.
Old 27-04-2013, 11:35 AM   #16
Yellow_Festiva
Where to next??
Not a bad price, but I'm after Ford service customers. Cheers
Old 27-04-2013, 11:42 AM   #17
In Focus
I've had three "A" Ford services in the last 12 months, two on a Fiesta, one on my old Focus. Apart from trying to upsell me something on one occasion (wheel alignment from memory), each service cost whatever the capped price was -that is, the full capped price.
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red.
Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White.
Old 27-04-2013, 01:27 PM   #18
prydey
Rob
prydey's Avatar
see below. thats sort of what i was getting at. rarely will it be less.
Old 27-04-2013, 02:20 PM   #19
Yellow_Festiva
Where to next??
In my case, the time and materials used came in under the cap, so they just fudged the figures and qty of oil used to make up the difference.
I questioned them about it and didn't want to make a fuss so left it. Till I found hard proof that they charged me for stuff they certainly didn't do. (both this service and in the past)
I may have engine damage as a result.....
They will not get away with it and have Ford CRC involved.
Seriously.... I wonder how many other cars have had the same treatment?
Old 27-04-2013, 02:54 PM   #20
PridenJoy
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For his contributions to the forum, especially showcased with his highly detailed AU build threads. He is a fountain of AU knowledge.
I stopped taking my car to get serviced at Ford. Just had a gut feeling something was wrong everytime i took it (I can't back it up as I have no proof). But after charging me $360, after fleet discount, just to change the oil and filter (plus a whole lot of 'checks'), that was the final straw.
Now Kmart Tyre and Auto look after it and do a much better job in my opinion for near half the price.
Ford servicing really need to pick up their game in terms of pricing and QA.
PridenJoy is offline   Reply With Quote Multi-Quote with this Post
