29-03-2013, 11:51 PM | #31 | |||
If there is, that will be how you access the fuel sender to replace the filter. |
30-03-2013, 12:08 AM | #32 | ||
I'll check it out Damo
30-03-2013, 12:21 AM | #33 | |||
31-03-2013, 12:44 AM | #34 | ||
Could someone please confirm if this is the correct camber kit to use
http://www.whiteline.com.au/product_..._number=KCA394 Thanks in advance |
31-03-2013, 10:25 AM | #36 | ||
Thanks DZ,
So does +/- 1° camber adjustment pull the wheel up fairly straight, my rears splay out a bit at the moment and 1° doesn't sound like a lot. I estimate mine has worn the inner edge of the tyres right down over a period of around 20,000 k's so it can't be too bad, probably the reason the guys that fitted the springs said it was alright at the time. Unfortunately once the springs settled it must have caused a little too much toe out :( |
01-04-2013, 10:31 AM | #37 | ||
My Bilstein shocks came in a few weeks ago, I'm 1000km overdue for a service, so I'm going to get the oil and filters, then take it to my mechanic and he can do my shocks/rear sway bar and service for me.
Do they lower the car anymore? Because I don't really want to push it too low, its low enough as it is. |
01-04-2013, 11:59 AM | #38 | ||
Where to next??
Just did the drivers side head light...
2nd time I changed it in 3 years... same with the other side. Seems a little excessive seeing as I think I only ever changed 1 headlight globe in the 10 years I had the Festiva...
01-04-2013, 05:57 PM | #39 | |||
01-04-2013, 06:10 PM | #40 | |||
Let us know how the car handles - with your Bilstein shocks + Eibach Springs + Whiteline Rear Swaybar, it should handle like a dream |
01-04-2013, 07:15 PM | #41 | ||
Does anyone know what brand the standard shocks are in an LV Zetec, would I benefit by changing them for shorter shocks ? I can't really afford to go any lower on the front though, the SL's are already pretty low, any lower and I think scrubbing could become an issue :(
01-04-2013, 09:29 PM | #42 | ||
Koni Yellow or Bilstein B8 shocks would definitely improve your cars handling. They are both designed to work with lowered springs.
And I speak from experience...I went from Eibach Springs with OEM shocks (the latter eventually gave up), to Koni Springs with Koni Yellow shocks and there was a huge difference in handling performance. To the point where I'd never fit springs alone to a car again - I'd always be looking to go to a matched spring / shock combo. |
01-04-2013, 10:26 PM | #43 | |||||
Haha before I converted to HIDs I blew around 4 or 5 pairs. But I drive with my lights on all the time and had the +100s which have a shorter life for better light output. If you want something long life, check out these: http://www.powerbulbs.com/au/product...eadlight-bulbs They have a slightly better light output over normal globes but not as good as the OSRAM Night breaker plus or Phillips Xtremevision +100s (All still 55W). Quote:
Hopefully, she's real nose heavy with the cast iron diesel engine up the front, and these crap Toyo TEO PLUS tyres, only good for high milage and low noise, once they go down past 60% tread you can spin em without even trying and get it to push wide easily. This thing handles like a boat compared to my WS Fiesta, but the Fez is like 300kg lighter, and the Focus handles like a go-kart compared to my EL Fairmont Ghia, that thing is woeful, lol. Quote:
05-04-2013, 03:47 PM | #44 | ||
Barra Turbo > V8
60k service.
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
05-04-2013, 04:01 PM | #45 | ||
60,000 klm that would be a B service as in Big Bill.
05-04-2013, 04:48 PM | #46 | ||
Barra Turbo > V8
Indeed it is, but alas i never went to Ford so the hit wasnt as big.
05-04-2013, 06:45 PM | #47 | ||
Had the rear camber kit fitted, 18's on and wheel alignment done, oh wow what a difference it's made, the Nitto Invo's are so quiet compared to the stock Good Years and they stick to the road like the proverbial to a blanket and the ride is as good if not better on the 18's than it was with the 17's
A quick pic taken with my iPhone |
05-04-2013, 07:16 PM | #48 | ||
Barra Turbo > V8
Looks sweet Russ, stance is spot on. Wish i could lower mine but driveway is munted.
I also rooted my bonnet latch today, bonnet wont open
05-04-2013, 07:27 PM | #49 | ||
Thanks Dallas, yeah I'm pretty happy with the result, next upgrade will be short shocks and then I'll hopefully look into tuning prospects There was a post on the XR5 Forum regarding an upgrade to a cable release for the bonnet but it sounds like a bit of messing around involved to do it :( There were quite a few guys complaining about them failing, I think the secret will be to keep the mechanism and lock well lubricated to help with longevity
http://www.fordxr5turbo.com/forum/in...?topic=16782.0 Apparently one of the guys did a DIY thread on the manual cable upgrade, it's on here - http://xr5ownersclub.com/forum/viewt...p=95280#p95280 Last edited by Russ; 05-04-2013 at 07:36 PM. |
05-04-2013, 08:01 PM | #50 | |||
We spent like 30 minutes with two flat blade screw drivers trying to put it back into its hole. |
05-04-2013, 10:25 PM | #51 | ||
Looks great Russ, also loving that stance.
05-04-2013, 11:12 PM | #52 | ||
Thanks DZ and thanks again for your help along the way
06-04-2013, 10:12 AM | #53 | ||||
Barra Turbo > V8
06-04-2013, 12:54 PM | #54 | ||
Where to next??
06-04-2013, 01:10 PM | #55 | |||
Where to next??
Will buy those and just keep them on the shelf when these new one blow. BONUS!! Free W5W side lights (the lights used in the rear hatch area). I was trying to buy them for my Focus at the same time and there were none hanging and the whole store had 2 staff working that were both serving a long line of customers at the register... on a 20% off day of all things! Win Win
07-04-2013, 09:05 AM | #56 | ||
Barra Turbo > V8
Washed, waxed etc. Now time to take it out for a blat through the hills.
07-04-2013, 04:10 PM | #58 | ||
Your car is looking great Russ. Once again, those king springs give the car just a really nice stance.
Just a quick wash for mine today. It really needed it - the wheels were COVERED in brake dust after putting new pads in a couple of weeks ago. |
07-04-2013, 04:16 PM | #59 | ||
Thanks DZ, I'll have to try and get along to a Focus day some time, it would be nice to meet a few of the guys from behind the keyboards I like the wheels on yours but they must be a bugger to keep clean ? The XR5T rims are great and even easier to clean than the stock rims were
07-04-2013, 05:16 PM | #60 | ||
They are a PITA to keep clean. So many spokes.
