25-01-2013, 09:02 AM | #1 | ||
I bought a car yesterday and when I asked the guy about the RWC, he said there wasn't much at all to fix, just handbrake and number plate lights. Now when I got an RACV inspection the inspector noted down that there was a leak on the steering rack(both ends), pads were only 2mm and discs lightly scored, and the windscreen had a small chip and was sand blasted, also the exhaust muffler had corrosion on it.
So the guy told me that the road worthy place didnt have to fix any of that..? I just think it's a little strange. On the RWC sheet, it has the owners brother down as the guy who took the car in there, and it also has the brothers name on the line where it states 'vehicle inspector signature' Also, where it states fixed defaults there is nothing written there.. So I don't know what to do, what are my options? And is it worth it? |
25-01-2013, 09:46 AM | #2 | ||
Understand your frustration, but the items noted by the RACV inspector may not be unroadworthy. Brake pads from memory need to be 1.5mm to pass roadworthy. Corrosion on the exhaust is o.k provided the exhaust isnt leaking. Chip in windscreen depending where it is and whether or not it is or could hamper the drivers vision. Oil leaks also dont deem a car unroadworthy, it depends on how bad they are.
25-01-2013, 09:50 AM | #3 | ||
You bought the car before you got the racq inspection done? Sounds super dodgy to me. New steering rack and new brakes and windscreen, no change out of $1200 there. Those 3 things are needed for a roady
25-01-2013, 10:01 AM | #4 | ||
Not sure Fordomatic about the guidelines in QLD but in VIC thats not nessesarily the case. Im a Licensed Vehicle Tester so hopefully I should know. I do agree with you however that you should get the inspection done before you purchase the car, and get any faults fixed or use them as leverage to lower the price. So many people get vehicle inspections done after they buy the car. For the life of me I dont know why
25-01-2013, 10:30 AM | #5 | |||
LIFELONG DJR SUPPORTER
How much did you pay? Private or commercial seller? Are you happy with the car otherwise? Why buy, then get inspected? You have a right to ensure the car is in a RWC condition. And will get support to get it there. Remember, RWC and a RACV inspection are 2 different things.
25-01-2013, 10:37 AM | #6 | |||
Buy a car, than have it inspected = Epic face palm!
25-01-2013, 10:54 AM | #7 | ||
Nah I had the car inspected first, racv gave it the ok to buy. Just noted some things down for info.
Most of the things I would of thought would of been in the RWC, such as windscreen and the leak. But either way, what about his brother signing the owne of vehicle and also the RWC tester.. I am willing to get a re check from racv for 80bux. |
25-01-2013, 11:10 AM | #8 | ||
Doesnt matter who checks or signs of on the RWC
They have to be a licensed tester/inspector Mite be a bit dodgy,in the sense,if in doubt get it checkout thoroughly,independantly IF you then find faults, that were passed,and legit issues you can take the matter futher If the 2nd independant test is fine, then its all good Remember once that RWC period has expired, its all your problem,and your liable for any RW issues,get it sorted quickly |
25-01-2013, 11:16 AM | #9 | |||
Would have to see RWC but the persons name on the RWC is not nesessarily the owner, its the name of the presenter. Anyone can present the car for roadworthy, friend, relative, etc. Nothing illegal about the salesman brother doing the RWC as long as he is a L.V.T. Its probably poor business practice tho not to use your brother, it suggests to customers that something dodgey is going on even if there isnt. P.S A RWC indicates the car is in a safe condition at time of inspection. I would suggest if your Brake Pads have only 2mm left they would need replacement very soon! |
25-01-2013, 11:42 AM | #10 | ||
http://www.vicroads.vic.gov.au/Home/...oadworthiness/
Do you have a problem with the inspection or certificate for your vehicle? If you believe that your vehicle was not roadworthy when you were given a certificate, then take the following steps:
What are your legal rights? VicRoads does not have authority to require the tester to make good your vehicle or otherwise compensate you. These are matters for civil action. You can seek professional legal advice from a solicitor, take your dispute to the Victorian Civil and Administrative Tribunal (VCAT) or through the Magistrates court. Where a vehicle is purchased through a Licensed Motor Car Trader (LMCT) Consumer Affairs Victoria may be able to resolve the matter through negotiation with the LMCT. |
25-01-2013, 12:45 PM | #11 | ||
Thanks for that man, cleared alot of things up. Its too much trouble for me to go further.
I am happy with the car, and it all seems fine so it should be ok, was just concerned with his brother doing the roadworthy but it all seems fine. Hope it holds up well anyway |
25-01-2013, 01:26 PM | #12 | ||
Experienced Member
Cannot understand if you had the car checked by RACV and happy with results then whats the big deal who done the RWC.
RACV would have told you if something was wrong. |
25-01-2013, 04:33 PM | #13 | |||
25-01-2013, 04:45 PM | #14 | ||
Obsessed with wheels
If your and doubt go and get it RWC at another inspection station. As RACV or Q whatever state you're in are alot more in depth, and they tell you things about the car that might go wrong down the track. But at the time will still past RWC.
25-01-2013, 04:55 PM | #15 | ||
Ive done roadworthys for my self when ive been selling a car dont see anything wrong with that dosnt make me dodgy at the end of the day if its not roadworthy and i sign off on it im the one in the poo. If you feel you are not happy with the rwc take it to another rwc tester not the racv that way you can get a proper list and if you have any issue's then you can take it up with the person who did the first rwc. easy.
