Old 04-01-2013, 10:05 AM   #1
kate648
kate648's Avatar
Default Putting drivers door back together!
Hey guys, I've decided to ditch the electric window since I have now got 3 regulators that don't work.. I've picked up a manual winder regulator and door card, new glass and rubbers.. and I really don't know where to go from here!! I'm no good with doors- I probably should have been paying more attention when pulling them apart.
kate648 is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 10:15 AM   #2
Travisty FTT
'06 Ford Territory Turbo
Travisty FTT's Avatar
Default Re: Putting drivers door back together!
Not sure if this helps, but here's the locations for the electric and manual toggles.
http://fordforums.com.au/showpost.ph...5&postcount=28
Travisty's Ford Territory Turbo Project
Car History - No crashes, just a lot of shitboxes...
1988 EA Ford | Sept 2007 - Apr 2008
1995 EF Ford | Apr 2008 - Oct 2008
1998 AU Ford Forte | Oct 2008 - Mar 2011
1996 EL Ford Fairmont Ghia | Mar 2011 - Sept 2012
1999 AU Ford Sports Pack | Oct 2012 - Dec 2014
2003 AU Ford S3 XR6 | Sept 2014 - Apr 2018
2005 Ford Territory Ghia | Apr 2018 - Aug 2023
2006 Ford Territory Turbo Ghia | Aug 2023 - Now
Travisty FTT is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 10:22 AM   #3
kate648
kate648's Avatar
Cheers dude looks like it might help. I just don't know how to attach the regulator to the window again lol. I picked up a new window that still has the clips attached as my old ones were buggered
Old 04-01-2013, 10:38 AM   #4
Travisty FTT
When you say clips are still attached, do you mean the ones in the picture below?
If so, you'll have to use two flat head screw drivers and pry them off, slide the window out altogether (by tilting the window on an angle to pull it out), glue the clips back on to the window by using Sikaflex 230, do not use standard siliconne as you'll just have to do it again as it won't bond to the glass.
http://i33.photobucket.com/albums/d8...50910_1334.jpg
Old 04-01-2013, 05:52 PM   #5
SSD-85
How thoroughly have you checked the whole mechanism? Electrics included.
More information may reveal that youre simply missing something.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 05:58 PM   #6
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Lol, probably just the switches have gotten clogged up with crap over the years. I had no working switches in the Fairlane, cleaned them out and now they work.
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 04-01-2013, 07:10 PM   #7
kate648
kate648's Avatar
When I pulled the window out of mine the clips basically fell off - seems like they had been dodgily stuck on a few times given the amount of **** on them.. I had no problems pulling windows out at the wreckers yesterday with the plastic clips still on.
Yeah didn't check the whole lot too thoroughly.. there was one i could hear trying to work when i had the door apart, but the window wasn't going anywhere.. so can't be the switches (i think lol). Now I spent 3 hours at the wreckers yesterday finding an au with manual winders in the front - I'm not changing my mind again! :p
Cheers guys
