Old 13-12-2012, 07:34 AM   #1
Lajon
Default Help removing rear rotors
Hey all, I recently changed the rear rotors on my AU Lane and the end of one of the screws was rounded so I used a red lictight stuff to make sure it stayed tight... well problem now is that the handbrake needs adjusting desperately but I now can't remove it! Please help!
Lajon is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2012, 07:41 AM   #2
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Default Re: Help removing rear rotors
Remove the rubber grommet from the rotor and you can line it up with the hand brake adjuster to adjust the handbrake.
You'll need a propane torch and impact driver to get that screw out in future.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2012, 01:33 PM   #3
Sox
RIP...
Sox's Avatar
An impact driver should do on it's own.
Oval Everywhere...
Old 13-12-2012, 01:42 PM   #4
STINKY NINJA
I make a habit of buying new lock screws before i remove the rotors in case they get damaged when removing.
STINKY NINJA is offline   Reply With Quote Multi-Quote with this Post
Old 13-12-2012, 06:53 PM   #5
Lajon
where do u get the lock screws from?
how much does an impact driver cost roughly?
Old 13-12-2012, 09:08 PM   #6
Sox
RIP...
Sox's Avatar
Don't worry too much about the screw, they're not really needed, the wheel/nuts hold the whole assembly together.
Just get a cheap impact driver, it'll do the job fine, maybe $20.
Oval Everywhere...
Old 15-12-2012, 10:35 AM   #7
Whoosha
AU DIE HARD
Whoosha's Avatar
Was going to say the same but got side tracked old age I guess ,you can put some never seize on the threads if you like as this helps them from locking on (caused by heat transfer from all that braking ) or just nip them up as Sox said they're held in by the wheels any ways
Originally Posted by Riksta
Old 15-12-2012, 10:22 PM   #8
STINKY NINJA
Ford still sell the screws,cost bugger all, i agree on the antiseize and they only need to be nipped up not super tight as already mentioned.
Old 19-12-2012, 08:46 PM   #9
Lajon
G'day.. local mechanic ended up drilling out the screws..so i'll have to get a new set... just to be sure i turn the handbrake adjuster clockwise to tighten?
