Old 06-12-2012, 03:11 PM   #1
fordmfp
Blue blooded
fordmfp's Avatar
Default Rough idle in gear???
Hi Guys
Ive just got myself an AU2 Fairmont wagon 6cyl. It starts and runs really good and idles around 800-900rpm smoothly but when i put it into gear (reverse or drive) the revs drop to around 400-500rpm and it seems to run rough and sometimes sort of splutters a bit when i accelerate.Once its running it drives beautifully around town and open road. What would be the best things to start checking?
Dwayne
My XA Coupe build
http://www.fordforums.com.au/showthread.php?t=11259539
fordmfp is offline   Reply With Quote Multi-Quote with this Post
Old 06-12-2012, 08:34 PM   #2
AUFanboy
Default Re: Rough idle in gear???
Try cleaning throttle body and ISC first, easy and free. Then I'd be looking at the intake manifold gasket, it seems to be a common failure. About $15 and a couple hours work with a 10mm ratchet spanner. Normal idle speed is 550 rpm so they are hard to get completely smooth at idle... I've replaced/checked almost everything on mine and can still feel a slight vibration at idle, but it runs fine otherwise.
AUFanboy is offline   Reply With Quote Multi-Quote with this Post
Old 07-12-2012, 05:42 AM   #3
fordmfp
Blue blooded
fordmfp's Avatar
Ok thanks for that mate i'll try those and see how they go
My XA Coupe build
Old 07-12-2012, 09:26 AM   #4
Maka
Au Falcon = Mr Reliable
Maka's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Embodiment of the AFF spirit in his efforts with ACP.
G'day fordmfp, fuel filter is worth looking at also.
cheers, Maka
Ford AU Series Magazine Scans Here - www.fordforums.com.au/photos/index.php?cat=2792
Proud owner of a optioned keeper S1 Tickford Falcon AU XR6 VCT - "it's actually a better-balanced car than the XR8, goes almost as hard and uses about two-thirds of the fuel" (Drive.com 2007)
Maka is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2012, 04:37 PM   #5
fordmfp
Blue blooded
fordmfp's Avatar
Hey guys quick update i had a look at the intake manifold bolts (DAM THEY ARE TRICKY TO GET TO) and got about half a turn out of each, I didnt think half a turn would make a difference but wow what a difference, It is idleing awesome now!! No shaking at all. I will get a new gasket for it at some stage. Now im going to give the throttle body a clean to see how that goes.
Cheers for the help
My XA Coupe build
