Drag Racing Discuss Drag Racing here be it dirt or tarmac. Sponsored by Sydney Dragway. |
06-11-2012, 07:13 PM | #1 | ||
My XT is knocking on the door of a 10 second pass.
What do I need to do to be able to race the car & keep ANDRA happy?
'68 XT Fairmont, 9.48@141.6 '69 Capri '95 triumph speed triple, '10 Fat Bob My XT Fairmont http://www.fordforums.com.au/showthread.php?t=11298079 My capri track car http://www.fordforums.com.au/showthread.php?t=11492523 |
06-11-2012, 07:29 PM | #2 | ||
Andra licence and cage
12.33@112mph (stock) 11.00@125mph 98 (387rwkw) (CMS) 10.19@139mph (450rwkw) (Nizpro)(SOLD) 10.25@138mph FG XR6T (new toy) (Nizpro) |
06-11-2012, 08:16 PM | #3 | |||
We can run as low as 10.5s before we need cage on a wednesday night but im not 100% sure about racing events |
06-11-2012, 08:23 PM | #4 | ||
XA GT
--------------------------------------------------- XA GT, 6.848sec 1/8 mile @ 101.68mph |
06-11-2012, 08:37 PM | #5 | |||
Some mates do the nostalgia meet & I believe that comes under ANDRA rules. Id like to give that a run Im going to take the old girl down again on the 21st. Are you going to be able to give yours a run then? It would be nice to meet up mate
06-11-2012, 08:39 PM | #6 | |||
06-11-2012, 08:40 PM | #7 | ||
Whats involved in getting an ANDRA licence?
Cheers Brad
06-11-2012, 09:14 PM | #8 | ||
10.99 and lower is an Unlimited Licence. You will require a medical certificate.
06-11-2012, 09:17 PM | #9 | |||
Any driving requirements? Ive had motorcycle road racing liceces & that required actually riding your bike with the club captain How much is a licence?
06-11-2012, 09:38 PM | #10 | |||
Just got a couple of gremlins to get rid of first |
06-11-2012, 09:42 PM | #11 | ||
Contact andra .
They have all the licence info and pricing . Bout 370 for unlimited , you will run in Super Sedan . You have to ask , adding the weight of cage , will that put you back on 11.0 ??
1998 AU VCT Ghia - Stock as a rock - Wifes car 1991 Toyota Soarer TT - 11.72 @ 116.7mph 2004 Ford Escape XLT V6 - Family Ride . |
06-11-2012, 09:46 PM | #12 | |||
Andrew is going to bring his 66 mustang down on the same night as well (the car with the 427 that Simon built) It will be nice to see the Ford chrome bumpers amongst the sea of commodores
07-11-2012, 08:33 AM | #13 | ||
usually you have to do a couple licensing test passes, they watch u do a burnout, 60ft, 1/2 track then a full track pass before they sign off on it.
07-11-2012, 09:33 AM | #14 | |||
How much will a cage weigh roughly?
07-11-2012, 10:21 AM | #15 | ||
07-11-2012, 12:14 PM | #16 | ||
07-11-2012, 01:12 PM | #17 | |||
Thats what I was thinking of doing
07-11-2012, 01:40 PM | #18 | |||
Spose if ANDRAs cut off is 10.99 then could be worth it but if there cut off is 10.5 same as wednesday nights then is it worth all that hasle for .5 ? |
07-11-2012, 01:54 PM | #19 | ||
is the car tubbed or untubbed?
07-11-2012, 03:09 PM | #20 | |||
ANDRA events are still 10.99 It is a lot of money for the step though ANDRA licence, harness, cage & there is bound to be more things as well.
07-11-2012, 03:10 PM | #21 | ||
The XT is untubbed, why is that?
I run a 275/50 M/T street radial at the moment
07-11-2012, 04:56 PM | #22 | ||
[QUOTE=brad24;4509756]I believe its only the Wednesday night street meets that are 10.5
ANDRA events are still 10.99 It is a lot of money for the step though ANDRA licence, harness, cage & there is bound to be more things as well.[/] Also need a race suit, also depending on mph rear disc or parachute
It's my call pizzoff, and I just called it |
07-11-2012, 05:00 PM | #23 | |||
Would probably be as easy as taking out a couple of degrees of timing for ANDRA events then put it back for Wednesdays |
07-11-2012, 05:45 PM | #24 | ||
Bolt in 6 pt cage if standard tubs , has to be weld in if tubbed
07-11-2012, 08:18 PM | #25 | ||
07-11-2012, 08:40 PM | #26 | ||
07-11-2012, 09:41 PM | #27 | ||
4.14.4 Single Rolover Hoop with removable support members
The following vehicles require a single rollover hoop covering the full width of the driver's compartment with two back stays , a side intrusion bar and taxi bar of bolted construction using Grade 8 or equivalent fasteners constructed to ANDRA requirements as a MINIMUM ! ( Utilities may use a FOUR point rol cage with intrusion bars / diagonals on both sides ) . Unmodified cars ( ET 10.00 - 10.99 ) : with nmodified monocoque construction with fixed steel roof , slower than 10.00 ( 1/4 ) / 6.50 ( 1/8 ) but faster than 10.99 ( 1/4 ) / 7.00 ( 1/8 ) . My understanding of that is , UNtubbed = unmodified , therefore a Bolt in 4 point cage with Bolt in Side instrusion bar which is always on drivers side ? So a back half cage with bolt in drivers side intrusion bar is required for Unmodified chassis/tubs ..... Hope that helps , but if in doubt , contact your local Andra Tech inspector for more info . This is from the 2013 Andra rule book . 4.14. Full 6 Point Roll Cage with Removable Support Members . The Following vehicles require a full roll cage mounted at a minimum of 6 points with removable side intrusion bars . The intrusion bars must be the same diameter and thickness as specified in the material selection chart and must be attached using 3/8 inch ( 10mm ) Grade 8 bolts as a minimum . UNMODIFIED CARS ( et 8.00 - 9.99 ) . Street registered cars with a fixed steel roof and Unmodified monocoque construction running between 8.00 and 9.99 ( 1/4 ) / 5.00 and 6.25 ( 1/8 ) or slower . So STREET Registered cars with FIxed Steel roof and UNMODIFIED chassis or tubs , ONLY needs BOLT in 6 point CAGE with BOLT in removable side intrusion bars . WOW SO basially you can keep your registered car with unmodified chassis / tubs , streetable with all seats available with some Hard Work of making a Bolt In 6 point cage ! Thats got to be appealling to alot of people ... Thats cool .... DAMN cool
08-11-2012, 08:41 AM | #28 | |||
As for cages Brad (sorry iPhone won't let me post a link) go to you tube. Type in XY GT 351 posted by Why Chuchie and have a good look at that cage, andra approved and can barely see it in car... With lightly tinted windows you'd have no hope of seeing it ...
08-11-2012, 10:39 AM | #29 | |||
08-11-2012, 10:41 AM | #30 | ||
Your welcome. A good cage will do its job and not look gaudy. Plus on the street no one really needs the heat from wallopers
