07-12-2005, 04:01 PM | #1 | ||
Da Shifty One
Howdy PPLs,
I currently have a pod style setup for my Fiesta. I have the stock plastic piping running from the throttle body to pod, but it is just above the manifold, so it get hot 95% of the time. I have put an insulation sleeve over the pipe but its still gaining heat for some reason. Can anyone recommend a product that would fix this perminatly or would it be best to use silicone hosing? But my main concern is finding an air box about the 20cm X 10cm X 10cm so i can put the pod in. The rate the weather is going its getting hotter and hottter and my car is loosing performance. Is there the option of getting one custom made? Any help would be greatly appreciated Cheers Damo
2013 Ford Fiesta ST - Frozen White - AU 0072/XXXX
- Mountune ST180 Intake Hose - Mountune Quick Shifter - J1 ST180 MAF Adapter - K&N Apollo CAI - Triple R Front Splitter - Richbrook Shorty Aerial - DMB Gel Overlays - LED Interior Bulb Upgrade - Last edited by MISTA FIESTA; 07-12-2005 at 04:06 PM. |
07-12-2005, 04:14 PM | #2 | ||
PM me if you want
Use an EA air box
got a pic of the current setup and the space you need to fit the air boc in.
Owner of first ever car to retrofit BA SSS - the EA2BA Send me a PM if you want to know anything 2010 Ford Ranger PK High Rider (Auto) - 2011 Ford Fiesta (Auto)
07-12-2005, 04:18 PM | #3 | ||
hibernating
you could put one together yourself out of perspex or something
07-12-2005, 04:46 PM | #4 | ||
Da Shifty One
This is the bay. As u can see there isnt alot of room, but i know something can be done.
- Mountune ST180 Intake Hose - Mountune Quick Shifter - J1 ST180 MAF Adapter - K&N Apollo CAI - Triple R Front Splitter - Richbrook Shorty Aerial - DMB Gel Overlays - LED Interior Bulb Upgrade - |
07-12-2005, 04:49 PM | #5 | ||
Forum Director
was you going to end of year eurofordclub run? I might bring a different vehicle to show you something...
07-12-2005, 04:56 PM | #6 | ||
Da Shifty One
Hey Wulos,
Yes i will be at the euroford club dinner. What do u intend on showing me? Also instead of a new airbox, is there anything that can be used to cove the pod. Ie ive seen the new K&N Apollo filter and its got a metal covering over the whole pod.
- Mountune ST180 Intake Hose - Mountune Quick Shifter - J1 ST180 MAF Adapter - K&N Apollo CAI - Triple R Front Splitter - Richbrook Shorty Aerial - DMB Gel Overlays - LED Interior Bulb Upgrade - Last edited by MISTA FIESTA; 07-12-2005 at 05:01 PM. |
07-12-2005, 06:41 PM | #7 | |||
Forum Director
metal cover = good heatsink.... |
08-12-2005, 08:51 PM | #8 | |||
GT4.
Imagine that big EECIV airbox in the Fez. Then I'd be able to cruise with the eseries club again. Only if it was held with cable ties. |
