Hi All, my name is Adam and i own a auII forte sedan, it is a soild family car and tows the van well but i m haveing some trouble with and intermitant sarting fault.The car is dual fuel.
Fault - when i turn on the ignition the smart shield hand comes on if it goes out the car starts but idels roughly then it settels down and runs a treat. If the smart shield does not go out but flashes there is nothing when i turn the key to start. If this happens i put the car in N rock it back and forward and the smart shield hand stops flashing - that car starts as above. What have i had done so far - replaced the N safety switch (not sure if that is the tech term)tells the car it is in P or N Replaced the control module (controls the electronics so i was told) Fuel system clean and service. In addition in the past 6 months i have had the radiator,power steering pump, alternator replaced. I am at my wits end with the car and i would love to here from anyone with the same issue or possible soultion. As you can proberbly tell i am not very tech savy with cars is if you can keep it simple that would be great. Thanks Adam |
Awesome
Location: In my own little world..Everyone here knows me :)
Hello Adam and welcome to the forums. I have moved your post to the correct part of the forum, so hopefully someone will be able to help you resolve your issue.
Cheers Col
welcome mate, i`m pretty computer illiterate myself(really a points and carby bloke
#4 | |||
Hi thanks for the reply, the au has done 160000kms, battery less than 3 mths old, terminals good. do you know where i can find the ecu? What does it look like? i have had the starter tested and it is supose to be ok, should i look at changing it any way?. Cheers Adam |
rexnet
ECU is right hand kick panel. its a silver box. it would be pretty hard i assume to test it unless you have the right plug in stuff.
#6 | |||
#7 | |||
Bugger!
Sounds like the Smartshield - factory imobiliser - isn't disengaging. I'd suggest rocking the car back and forth is probably not what's fixing it, but rather the vibrations. Perhaps you could try whacking the dash with your hand. I'm not sure with the Smartshield, but with the older Smartlock models the body control module is located above your left knee. I'd imagine it's in the same place for Smartshield....
Was the module replaced with a new or secondhand unit? Possibly could be the ignition barrel or wires leading from that to the BCM. Engine computer is located behind the passenger side kick panel, you could check the earth and plug on that but since the Smartshield isn't deactivating I'd be surprised if it helps!
Whoops, there goes another factory setup! Chop and change - butchering cars since 1990 ![]() |
#9 | |||
Bugger!
Hrmm ok then, that leans me towards a faulty or worn ignition barrel. Perhaps next time it does it, try giving the steering column a tap or wiggling the key/turning it off and on a few times; if that helps then it's starting to look as if it may be the barrel.
