Audi S3
alright, so im having trouble removing the headlight globes on my car...
im following the instructions in the manual, but it just isnt working. i try and remove the rubber thing and it wants to pull on the spring that is holding the globe in place. and i dont want to put too much tension on it incase i break something... would i be better off pulling the headlights out and wrestling around with them on the work bench? /stupidest question ever.
not the stupidest question ever at all, i had trouble trying to get the globes out of my headlights too. I just gave up though hahaha..
Miami Pilot
![]() Join Date: Jan 2005
Take the headlights out - it's much easier to do it that way. You will bend the spring if you keep pulling the rubber cover off and it doesn't come off easily, and then you have to pull the headlight out to fix it anyway.
Silhouette AU1 TS50.
First, remove the wires by pressing on the two tabs on both sides and pulling the plug out.
Second, remove the rubber dust cover by pulling it backwards and off. Third, remove the spring retaining clip by pressing in and outwards. Forth, remove the bulb. It's not that hard at all. I have done both sides on my previous car (AU1 XR8) and current TS50 a few times.
"People can have the Model T in any colour.. so long as it's black." HENRY FORD (30/07/1863 - 07/04/1947) PIC'S OF MY T1 TS50.
#5 | |||
Audi S3
as JC said, ill probably just pull them out maybe? i wanna put a set of those pain in the *** bright white/blue halogen globes in.
holla at cha boy
i had trouble too, in the end i went to my mechanic and got him to do it, he took them out in 2mins. I didnt want to stuff anything up as the new globes i put in were phillips diamond vision and they arent cheap at $100 a pair.
Not that deep at all. About 2mm or so.
I don't know why so many of you guys are having trouble with removing the headlight globes on AU's. I don't know.. but it was/is pretty easy for me. Hmmm.. maybe a write up with photos, an article for aufalcon.com maybe. If I can find some time I might just do that.
#8 | |||
Audi S3
Winter all year round
Replaced one of mine on the weekend, done in 2-3 minutes. HLC, put your finger inside the hole of the dust protector and free the rubber from the clip.
Some people drive sports cars on the weekend....I drive my AU! It's not what you drive...it's how you enjoy it. Recommend trading with Mechan1k, Offyaguts, EDMONTY, PhantomXR8, HOTC2R, Partie & JC |
Boost Addict
just pull one of the headlights and have a very close look at how the lock in mechanism works, once you can visualize it, it is very very easy to unhook and remove.
basically as said above: 1. remove the wiring, by pressing the two clip of the plug in and pull off. this can be a little sticky if removed for the first time. 2. pull off the dust cover. it basically just sits there, again its pretty tight. I have found inverting it while pulling it off makes it breeze. 3. use a pair of a needle nose pliers if you have big hands and hold onto the metal bracket that sits inside the headlight. push that carefully in by 2 to 3 mm until u feel it become loose and pull it inwatrds towards the center by about 4 to 5 mm. that should clear the little hook. from there its just a matter of it springing open the the globe basically falling out. i think i have a diagram somewhere, ill have a look and post it if i find it ...
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO ![]() Can't live with it, can't live without it! |
#11 | |||
buickman
buickman |
#12 | ||
It's not the easiest job when you first attempt it, but only takes a couple of minutes the second time around. The service book instructions could have been a little better in this area.
#13 | ||
Audi S3
alright...
im quite positive that my headlight globes have never been changed in my car cause the little clip mechanisms did not unclip easy, and those O-ring dust covers did not make the job any easier. i ended up getting the s and pulling the headlights out so i could replace the parkers as well as the high beams and driving lights. now full of Narva goodness. but i think my front bar is hanging slighly lower?? where are the tightening bolts to tighten it up again?
#14 | ||
WA_AU
I had a simular problem that with many attempts I finaly got it. And felt stupid how easy it was heh. But the parkers on the other hand I just cannot get out. It appears to be held in by some plastic thats expanded once its gone into the headlight silver part thus making it impossible to get out. I have spent hours on this stupid :(
Anyone know bout taking these out? |
#15 | |||
Audi S3
#16 | ||
WA_AU
hmm i never thought bout putting finger in the headlight hole to pull out the parker
Thanks il give that a try :P |
#17 | |||
:nutsycuck
Removed by laminge |
#18 | ||
WA_AU
dam a bit of the plastic just broke off and is now in the stupid headlight assembly....
arg i hate my car now lol |
#19 | |||
#20 | ||
WA_AU
yep thats what happened :x
Plastic magnets? never knew u could get those... will look into it tommorow. Meanwhile i still cant get that dam $*(&# parker out!! |
#21 | |||
#22 | ||
i want to do the inside of my lights black but i'm way too paranoid i'm going to wreck something.. :'(
#23 | |||
Removed by laminge Last edited by The Dok; 28-11-2005 at 09:55 PM. |
#24 | ||
lol you're not making this any easier dok
#25 | |||
Audi S3
#26 | |||
#27 | ||
Miami Pilot
Thanks Dok - I sold mine a couple of weeks ago.
Glenn, if you follow the method on AUFalcon . com, you won't go wrong. I've done 2 sets using this method and the only trouble I've ever had is choosing what colour to paint the bezels. Of course, The_Dok has made a very generous offer that you would be mad to refuse!
