Old 06-05-2012, 11:50 PM   #1
BZINGA
Powered by Ford
BZINGA's Avatar
Default Brembo's fitted to AU
What was the Brembo package that was fitted to the T series and Pursuits?
Was it 6/4 .. 4/4 .. 4/1?
I'm thinking about a 4/1 set up for the ute rather than the BFxr8 fronts i intended on using. The 1 piston rears, are they just the standard AU 2/3 PBR's? Also with the 4 piston fronts, are they the same as any newer model or does the AU only fit the AU? What size rotors do these run?
Darren.
BZINGA is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2012, 03:58 AM   #2
blownv8au
Pro Street Au Ute
blownv8au's Avatar
Default Re: Brembo's fitted to AU
They ran 4 and 1, front rotor size 355mm, dont know about pbr rear but i think they areadifferent to standard. Au brembos are same as ba and bf.
Daily. AU XR8 s2 ute auto
Weekender. AU XR8 s2 sedan. 427 windsor, t56 magnum. 3.9 locker.
Old 07-05-2012, 08:36 AM   #3
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: For the effort put into the Australia day cruise to Albury Tech Writer: Recognition for the technical writers of AFF - Issue reason: AU Tech article.
I can confirm 100% they ran a 4/4 package. Have some on mine from a T3 TS50. 355mm front, 330mm rear rotors.
Front.
Rear.
Stu
2002 AU II LTD
5.6L 342ci T3 Short, AFR165 heads, Comp XE270HR-12 Cam, Brembo 4/4s(355/330), T3 5 spokes, LC-1 wideband, Whiteline HD swaybars, TCE 3K Hi Stall, PWR Auto Trans Cooler, Koni shocks, King Low Springs, Hurricane headers, 100 cpsi cats, Twin 2.5" exhaust.
Quarter Mile: 13.73 @ 105.86mph
Runner Up NA/DA to BF Fairlane/LTD Geelong AFD 2024
2002 XR8 pursuit 250
Custom twin 2.5" exhaust w Herrod modifed extractors, Tuned with Moates QH
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2012, 02:26 PM   #4
blownv8au
Pro Street Au Ute
blownv8au's Avatar
Ment to add sedan ran 4/4. Pursuit ran 4/4 but had issues with rears and as far as i know went 4/1 because of this.
Old 07-05-2012, 05:45 PM   #5
BZINGA
Powered by Ford
BZINGA's Avatar
As mentioned i was only going to run 4/1 and mine being a ute seems the right option from what your saying. The premium brakes were standard rears but apart from Brembo i've never heard of the rears on series 2/3 being any other? Anyone know what they ran if not standard or Brembo?
Old 07-05-2012, 07:24 PM   #6
XR27
Tickford XR8
XR27's Avatar
I have fitted 6/4 brembo's to my au ll xr8 ute,
Haven't had any probs with rears.
XR27 is offline   Reply With Quote Multi-Quote with this Post
Old 07-05-2012, 09:28 PM   #7
blownv8au
Pro Street Au Ute
blownv8au's Avatar
I intend to run 6/4 on my ute but have been made aware there is a chance of pad knock off from wear in the diff bearings. Mono block calipers and disc movement dont go well together apparently. But there are ways to fix it. I've been told bigger bearings but myself will be running a floating diff anyway which should negate this issue, that is if i don't change my mind and put all my stuff in a sedan which i'm thinking about at the moment lol.
