Old 31-03-2012, 04:32 PM   #1
Jay.Blanket
Jay.Blanket's Avatar
Default How often do you top up your coolant?
So...
How often do you top up your coolant fluid and what do you use?
White TSHavoc
Go check it out at AUFALCON
http://aufalcon.com.au/jay.blanket
Jay.Blanket is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2012, 05:06 PM   #2
4ford
Default Re: How often do you top up your coolant?
Since I replaced mine some 12 months ago, I've not had occasion to add any more at all...hence I don't recall what I used!
4ford is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2012, 05:08 PM   #3
BHDOGS
90 tectaloy plus and whenever it needs it maybe every couple months.
BHDOGS is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2012, 06:08 PM   #4
SirHenry
Falcon Unbelievable!
Aluminium radiator with Nulon Red every 12 months usually flush it in spring.
SirHenry is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2012, 06:14 PM   #5
FGII-XR6
FGII-XR6's Avatar
Never top mine up as I have no leaks i drain and flush once a year using ford premix with demineralised water (I have a mate in the local ford parts who looks after me )
[SIGPIC][/SIGPIC]
Rides:
Old 31-03-2012, 06:31 PM   #6
Sox
RIP...
Sox's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: As recommended by Ropcher. Personifies the spirit of AFF.
I never top up, but change every few years with this and tap water.
http://www.nulon.com.au/products/Coo...ms/Ultra_Cool/
Oval Everywhere...
Sox is offline   Reply With Quote Multi-Quote with this Post
Old 31-03-2012, 10:40 PM   #7
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
I use nulon anti-freeze/anti-boil (plus inhibitor) long life coolant. I haven't had to add any in over a year. I don't ever do a 'flush' - a part of the cooling system will fail forcing a change soon enough. This goes for just about everyone.
Old 01-04-2012, 12:21 AM   #8
mik
mik's Avatar
except for the control freaks that change everything before it fails
Old 01-04-2012, 11:40 AM   #9
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
No topups, but use coolant conditioner from Natrad (has no antifreeze as I am informed this is the corrosive part on seals, hoses etc).
2002 AU II LTD
2002 XR8 pursuit 250
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2012, 07:37 PM   #10
rowan194
According to that page it's for pre-1984 cooling systems? The recommended Nulon product for AU1-3, both I6 & V8, is long life concentrated coolant. Did you get confused with the product name or are you really using that stuff in your rad?
rowan194 is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2012, 06:52 AM   #11
Sox
RIP...
Sox's Avatar
Yep, that's what I use.
I've never had a need for glycol (anti freeze/boil) and it's associated corrosion producing properties. Even in snow conditions.
Most people don't.
Oval Everywhere...
Old 02-04-2012, 10:01 AM   #12
webbiegareth
We have to top up a small amount every 3 months, but we don't have to add much though, maybe 1/2 a litre every 3 months? From the service history apparently there's a weap at the water pump, but since it's not using to much we haven't done anything about that one yet.
(No idea if it's 1/2 a litre, basically it'll go near the min mark every 3 months or a bit longer, then I top it back up to the max mark).
My mechanic puts in Nulon long-life coolant, I usually top up with demin water though.
I was told it's normal for these cars to use a bit of coolant though? I'm surprised to here everyone here saying they never need to top up!
webbiegareth is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2012, 05:36 PM   #13
Sox
RIP...
Sox's Avatar
It's not normal to use coolant.
If the coolant needs topping up every so often, there's a leak.
Oval Everywhere...
Old 02-04-2012, 06:44 PM   #14
last fairlane
last fairlane's Avatar
Cool Re: How often do you top up your coolant?
My AU series one
5 litres every week
it leaks around the water pump and the metal line close by
I use Supercheap $5 for 5 litres stuff
once a week
ive also had the argument about pre 84 cars
but when it runs out that fast who cares
its been like that for 5 years with no issues
thanks John
last fairlane is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2012, 07:01 PM   #15
blueoval
Critical Thinker
blueoval's Avatar
I have never needed to top up. I forgot what coolant was used when I have my cooling system flushed and radiator done. But if I was to, I would use De-mineralized water just to top up.
"Everybody was KungFu fighting..."
2022 Mazda CX5 GTSP Turbo
2024 Ford Everest Trend
1967 Ford XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
Old 02-04-2012, 09:55 PM   #16
Cúl-Báire
Never, I was going through a little bit a while ago due to a leaking bottom hose; however since I changed the hose no leaks. I flushed the system a few weeks ago, and use Nulon's long life concentrate mixxed with a bit of distilled water.
Cúl-Báire is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2012, 10:07 PM   #17
macman
macman's Avatar
Topped up my AU2 TE50 once every 6 months (very very slow leak from thermostat housing when hot).
Never needed to top up my AU1 TS50 - never leaked.
Always use Motocraft premix + distiller water in my AU2 and Tectaloy + distiller water in my AU1. Never use tap water in any of my cars.
macman is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2012, 07:31 PM   #18
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
I never top up the coolant, unless there is a leak. I have only ever found leaks where the heater hoses go into the cylinder block and at the back of the water pump.
What I do every service is check the pH of the coolant with a multimeter. If it is too acidic, I will flush out the system and start again.
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2012, 07:52 PM   #19
HI PSI
I put new coolant in every 2 years or engine change..... Whichever comes first.... :p
HI PSI is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2012, 09:16 AM   #20
rowan194
Over time this dilutes the coolant anti corrosion additives to nil. My welch plugs rusted out after about 18 months of topping up with demin water due to a slow leak.
Old 05-04-2012, 09:32 AM   #21
blueoval
Critical Thinker
blueoval's Avatar
That is true, but it's not like I top up with distilled water every week. It only on occasions, maybe once a year with about 250mL of distilled water. After 2 years I get the system flushed per normal.
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
