Old 06-03-2012, 05:39 PM   #1
b055m4n
Default hole in firewall
Hi fell'as, my sons xr6 has pulled the clutch cable adjuster nut through the firewall and ripping a circular fifty cent size hole in the bloody firewall.There's a tube section, that the cable passes through and the adjuster nut butts up against which is still attached. What a mess i think were going to have to replate and reinforce the panel somehow, anyone hear of anything like this before ??
b055m4n is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2012, 05:51 PM   #2
bartsau
bartsau's Avatar
Default Re: hole in firewall
Seems to be a common problem as there are plenty of threads on here about cracked firewalls around the clutch cable causing leaks into the drivers footwell. I am planning on beefing mine up in this spot while the dash and motor etc are out as it's going to be easier than waiting until it cracks like your sons has.
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust.
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
bartsau is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2012, 06:19 PM   #3
imbhvn
Here ya go mate might help you out http://www.ebay.com.au/itm/FORD-EA-E...item3a712a97b5
imbhvn is offline   Reply With Quote Multi-Quote with this Post
Old 06-03-2012, 09:56 PM   #4
b055m4n
yer looks like we might pull the brake booster out to plate it up, have to see if we can weld it or rivet it up looks like alot of rooting around..
Old 06-03-2012, 10:00 PM   #5
b055m4n
Thumbs up Re: hole in firewall
Originally Posted by imbhvn
thanks but i bought one today same price from the dealer.
Old 07-03-2012, 08:44 AM   #6
Rambunctious
Yea, cars are like that, the older they get, the more you have to root round with them.
Rambunctious is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2012, 10:55 PM   #7
mongrelEF
Bugger!
mongrelEF's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always offers competent advice. Always willing to help out in person. Never negative towards another. Always respectful. Always offers viable suggestions for solutions.
Very common problem, the next thing will be that the pedal box collapses - reinforce that while you're at it!
Whoops, there goes another factory setup!
Chop and change - butchering cars since 1990
mongrelEF is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2012, 09:34 PM   #8
rowan141
i just had mine fixed with that same bracket the best way to do is make a decent size steel plate ant attach the bracket to that for a wider range of support and i just epoxy welded and bolted mine to save the hassel of pulling half the interior out and it seems to be holding up fine a lil bit of movement but not that bad but yes common problem
rowan141 is offline   Reply With Quote Multi-Quote with this Post
