#91 | ||
and that's how it is
I would say because that would cut into the market for the EcoBoost Falcon.
1983 Ford XE Fairmont 2004-2009 2003 Ford BA Fairmont 2009-2010 2002 Ford BA Fairmont Ghia 2010 - 2014 2012 Ford FG MkII G6E 2014 - |
#92 | |||
#93 | |||
Believe it or not but the better transmissions play a big part in LPG's improved fuel economy. E-Gas was a continuous flow single point vapor system that did not meet Euro 4 Holden uses a sequential multi point vapor system that already complied to Euro 4 and now Euro 6 Last edited by jpd80; 22-02-2012 at 09:26 PM. |
#94 | |||
Rob
also, i wonder if the people that are saying the commodore's power and torque are ample for most people (i do agree) are the same people that bag the ecoboost 4cyl, which produces 1kw less and more torque. jpd - bigal was asking how commodore managed to get better figures from their inferior system, and you replied "6sp v 4sp". both ecoLPi and commodore run 6sp's. my guess is, since ecoLPi was already in the market place, the holden techs had a figure to aim at and beat. |
#95 | ||
I was referring to the jump Holden made, they still used their sequential multi-point vapor injection,
the only thing that changed was 4-speed auto to 6-speed auto and a slight change in calibration.. Vapor gives good economy numbers but nowhere near the power and torque, that's the difference. Ford could have done a 3.2 litre I-6 in EcoLPI and still exceeded Holden's figures If Ford had only wanted a vapor injection system, E-gas could have morphed years ago but Ford wanted a superior system. Last edited by jpd80; 22-02-2012 at 09:35 PM. |
#96 | ||
Peter Car
Even Holdens CEO praised the Falcon's EcoLPi and called it a "fantastic system".
The Commodores LPG is fail from a power, torque, significant cost and driveability standpoint. It has nothing on LPi except slightly better economy, at the cost of being a hell of a lot slower to 100. I'd expect LPi's economy figures to be better in the real world than Commodores LPG too, it would need a lot less throttle to get it moving with so much torque. |
#97 | ||
IMO, GM should have opted to use the variable intake/exhaust valve timing version of the LY7 engine for the LPG Commodore. This would allow engineers to match Ford's LPi engine in at least in terms of power. But that would mean a significant fuel consumption penalty so there goes GM's claimed fuel economy advantage right there...
PoweredByCNG: Sick and tired of all the ignorant 'gas is crap' comments out there. |
#98 | ||
SY TS AWD LPG TEZZA
"dieselesque torque". LOL 320Nm should never be called dieselesque unless it's a 2L diesel you're comparing it with.
I actually think the actual real world economy of a Holden LPG will not be that good. To get it moving, you have to kick it in the guts more, get it to use the lower gears more than the Ford. The Ford will just idle away with the LPi giving better response and instantaneous fuel corrections which the vapour system will not be as good at. Towing economy would be much better with the Falcon as the motor can hang around in it's sweet economy spot easier. The Holden will need to be switching down gears on every hill.
1st car 75 XB Fairmont wagon 302C converted to 351C. 2nd car 82 ZK Fairlane 351C 4spd AOD LPG/Avgas 3rd car 97 EL Falcon police car 4L auto dual fuel 4th car 90 XF ute (work car) 5th car 06 SY TS AWD Territory Orbital LPi 6th car 95 XG ute 7th car 2014 SZ Territory TX Petrol Fords all my life. |
#99 | |||
#100 | ||
Straight Eight
As much as I hate GM. And as little as I think of Holden's V6's. And as laughable as I find their 'latest' LPG offering... (Hell it's less power than Falcon's coming 4cyl turbo.)
I must commend Holden on eliminating the boost space tax. Sure to us petrol heads... or gas heads now... Falcon is superior, and we laud it's superiority. But show Mr and Mrs Everydayperson the boot opened up on an example from each... optioned with a full size spare, only to see one that has a big lump where you expect to put things... and one that has a big lump under where you expect to put things. Well, then it comes down to priorities. Falcon's showing cost, consumption and power. Commodore is showing no compromise cargo capability... And a Wagon! So well done red team. I look forward to our return serve to your soft, dangly, fleshy parts.
The Falcon is dead. Long live the Mighty Falcon. |
#101 | ||
Straight Eight
Should remember to read threads fully before posting.
With no real advantage at all. Go ahead and nail 'em Ford. If they dare to advertise their LPG (they will)... counter punch with your's. (they won't)
#102 | ||
Rob
Real world economy will be interesting
3.6 LPG: 180kw at 6000rpm and 320Nm at 2000rpm. ecoLPi: 198kw @ 5000rpm and 409Nm @ 3250. as always, holdens peak power is very high in the rev range. also having not seen a graph, there's a good chance fords ecoLPi will have a similar amount of torque at 2000 rpm. ecoLPi is also rumoured to be closer to 210kw as well. whilst power and torque may not mean much to the average punter, the more you have, the less throttle % you need to go the same distance. |
#103 | |||
Those peak power/torque figures are only important at wide open throttle, something most cars don't do regularly so the fight comes down to how the cars "feel' on the road, the price asked and the appeal to buyers. As Ford has shown in the past, you can have superior technology up to the hilt ans still not attract buyers. Remember this is fleet sales we're talking about, not private buyers so managers will look at price and economy. Has Ford over cooked it by taking way too long delivering a superior system that the market didn't really ask for? Interesting times ahead... Last edited by jpd80; 23-02-2012 at 08:50 AM. |
#104 | |||
#105 | |||
Rob
#106 | ||
I bet Holden will market their new LPG engine alot better than Ford, would be keen to see who sells more....the more advanced Falcon system, with little to no marketing or the more basic Commodore system, with what I expect will be seen all over the place with a proper marketing campaign....
FG GT...Supercharged Bliss |
#107 | |||
In the other thread (Falcon EcoLPi etc) Brazen mentions that he is getting 9.1L/100km in his EcoLPi FG Ute. Awesome economy! There was also a mention in that same thread of inner city couriers with heavy loads who went from the E-Gas Falcons to the EcoLPi Falcons and their economy went from 22L/100km to 15L/100km. It's only early days, but the word is getting about how good the economy is on the LPi. Shows that the tech advantage employed by Ford is delivering in the real world.
BA2 XR8 Rapid M6 Ute - Lid - Tint -18s 226.8rwkW@178kmh/537Nm@140kmh 1/9/2013 14.2@163kmh 23/10/2013 Boss349 built. Not yet run. Waiting on a shell. Retrotech thread http://www.fordforums.com.au/showthr...1363569&page=6 |
#108 | |||
#109 | ||
Can we get that Torque graph up in this thread please? It seems to have disappeared from the other thread...
I wanted to reference it with an argument I'm having with a guy over on carpoint but it's just a cross on the page now. Last edited by madmelon; 23-02-2012 at 02:25 PM. |
#110 | |||
#111 | ||
Brilliant, thanks!
#112 | |||
Ute Forum Moderator
![]() Join Date: Dec 2004
#113 | ||
Media at it again
Holden with 4 stars & Ford with 3.5 stars.. Also, why is the boot not a negative on the Holden when it is the same setup as the Ford one?? Holden http://www.caradvice.com.au/159889/h...modore-review/ Ford (from July last year) http://www.caradvice.com.au/129513/f...pi-lpg-review/ |
#114 | ||
Rob
its frustrating to read, but blind freddy could see it coming.
