Old 10-08-2009, 01:45 PM   #1
publicsp
Default ECON Switch Causing Falcon AU Fault
Not sure if this is where I should write this information, but it just might save a Ford Falcon owner a lot of money, frustration and time.
Background:
-Purchased a 1999 Ford Falcon AU, 140,000ks, good condition
-All OK, except vehicle would "surge/hesitate" slightly when maintaining steady speed at 50-55k
-Symptoms felt like have a loose chain on your motorbike when cruising at steady slow speed
-Fault would come and go, not consistent, made it harder to find
-Visited various well qualified mechanics, including the local Ford dealer
-Items repaired/replaced in the hunt for the elusive fault:
a) All tyres balanced and aligned, then fitted new rear tyres as they looked a little out of shape
b) Complete new exhaust system
c) New engine seals, dipstick, oil filler cap, all hoses checked
d) New spark plugs
e) New high tension leads
f) Compression checked
g) Fuel injectors cleaned
h) New fuel filter
i) New battery
One day, by chance, I flicked the "ECON" switch to "off" whilst driving with the fault and it disappeared!
Over the next few days I flicked it on/off/on/off when driving (always leaving it off) and the car became more consistently smooth
It is definitely the ECON switch, most days the car is perfect, if not, then a couple of "flicks" later, it is perfect again for the rest of the day.
Not sure how to make the fault disappear altogether, maybe someone else has had this happen.
Thanks.
NOTE: I searched all the Ford Forums during the hunt for this fault, could not find any reference, hence my reason to load this information to help someone else.
publicsp is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2009, 02:24 PM   #2
onfire
onfire's Avatar
I think and don't quote me on this, while in ECON mode its more inclined to change up gears quicker. While in PWR mode, it will hold the gears longer, which is a good thing when you're trying to sit on a low speed.
onfire is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2009, 02:56 PM   #3
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
50-55 can be the changeover point for the torque converter to lockup in 3rd or shift to 4th, and back again. On tired transmissions this can be uncomfortable. (Planetary gears? Solenoid? Crack in valvebody?) Chances are you've got a mild flare and catch between the gears. Flicking to pwr instead of econ changes where and if the gears shift, and if i remember correctly, doesn't allow 3rd to lockup. Or is that just keeping it in 4th that does that?
Any rate, we used to tell the cabbies to keep the trans in 3rd whilst driving in 60 or less zones. The AU boxes change to 4th just shy of 60, and you would get excessive changing 3-4-3-4-3-4-3-4-3-4-3-4-3-4-3-4-3-4 if you were constantly moving from 50 to 60 and back again as traffic would ebb and flow. Around town: 3rd and econ, highway/motorway (70 and up) 4th and econ. If pwr is what you prefer (personally i hate it) then thats fine too.
Old 10-08-2009, 03:39 PM   #4
Ghiadude
FORMERLY TX3DUDE
Ghiadude's Avatar
doesnt econ lengthen the shifts to make them smoother hence wear transmissions prematurely? I would've thought cabbies would leave it on power ?
Originally Posted by AL NZ
it wouldn't matter what FPV or FordOz call it, because it will be - The One.
Ghiadude is offline   Reply With Quote Multi-Quote with this Post
Old 10-08-2009, 05:56 PM   #5
Mr Hardware
i always thought it was that pwr hardens the shifts meaning more wear on the box.
Old 10-08-2009, 07:19 PM   #6
brad`
The Monty
brad`'s Avatar
ECON wears out the transmission faster, holds the gears open for longer and slowly changes where power slips it in faster and with out slowing the gears so to speak. in the end power is better but u go threw more petrol etc etc, but saves ur gearbox
brad` is offline   Reply With Quote Multi-Quote with this Post
Old 11-08-2009, 08:23 PM   #7
Stattic
Stattic's Avatar
economy mode most definitely does wear out your box quicker, the slower slipping changes cause a lot of heat and as its been stated, cruising around 60 is an issue
my cars actually been flashed to sit in gear longer to avoid this among other things
theres nothing wrong with shifting hard, its just uncomfortable for most, which is why cabbies dont use it.. they drive around all day the more comfort the better =)
Current
Blueprint 03 xr8
5 speed manual, Difilippo Quad Big Boy system, BPR CAI, BPR Custom tune, Underdrives
256rwkw
BA manual Typhoon
Fully optioned, 340rwkw@16psi (thanks Bluepower)!
The old ride....
AU Fairmont, cammed beast, R.I.P you made my p plate years bearable!
150.8rwkw courtesy BPR
Stattic is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2012, 04:11 PM   #8
hortiboi
hortiboi's Avatar
Default Re: ECON Switch Causing Falcon AU Fault
Background:
d) New spark plugs
h) New fuel filter
i) New battery
Thanks.
Publicsp
I've had the same problem with mine and have replaced the Tranny, leads, coil pack, sparkplugs before I realised the connection with the Econ button. I recon it's a loose connection or something in the button causing an intermittant fault. I'm aving the switch checked when i have the 1000km check on the reco tranny.
hortiboi is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2012, 04:14 PM   #9
falconnut
When was the transmission last serviced?
2001 Falcon Fairmont AU2
Big turbo coming
Lsd
falconnut is offline   Reply With Quote Multi-Quote with this Post
Old 01-02-2012, 04:53 PM   #10
hortiboi
hortiboi's Avatar
Reco tranny, 500 kms old...so, very recently. It's not the tranny, it's in the Econ switch.
Old 01-02-2012, 05:14 PM   #11
hortiboi
hortiboi's Avatar
Background:
d) New spark plugs
h) New fuel filter
i) New battery
Thanks.
Sorry, I didn't add this as a quote last time....Publicsp, I've had the same problem. So far I've dropped in a reco tranny, changed plugs, leads, coil...had the original tranny serviced and flushed before the reco was dropped in. Mechanic have all said 'it's an AU thing'...maybe it's the Econo switch that has a fault.
Old 01-02-2012, 06:59 PM   #12
ronwest
All Bran = Regular Member
Originally Posted by hortiboi
Publicsp
Hasn't logged on since April 2010 and only made that post so chances are they've moved on
Anyhoo, let us know if you get it sorted.
Old 01-02-2012, 07:54 PM   #13
hortiboi
hortiboi's Avatar
Bugger!
Old 01-02-2012, 07:58 PM   #14
ronwest
Bugger!
No problemo.
We've all done it (or almost done it, lol)
Old 01-02-2012, 08:07 PM   #15
hortiboi
hortiboi's Avatar
Ha ha...i just go so excited knowing there was more than one of us out there. I found my long lost brother
