31-12-2011, 01:13 PM | #1 | ||
Token American
Some idiot decided one of his last acts for 2011 would be to tear the antenna off of my AU. It is a power unit that wouldn't go all the way down, still worked otherwise and there is no excuse for such thoughtlessness. But I digress...
I looked in my Max Ellery manual under the body section and it had the helpful sentence "If necessary remove radio antenna." Yeah, thanks. Looking at the car though it appears that I could remove the top fender/wing/guard bolts and the metal should be flexible enough for me to get in there. Getting the antenna out may be another matter. Has anyone done this procedure without having to remove the front bumper cover and the fender? How did you do it? Here is a picture of a Ford power antenna that appears to have a bracket on the bottom. I'll probably fix it with the rope and antenna replacement bits. |
31-12-2011, 02:02 PM | #2 | ||
Token American
Upon further research elsewhere it appears that I won't have to take much apart after all. I'll do the deed and post pics later.
31-12-2011, 02:27 PM | #3 | ||
T3 TE50 Blueprint
El Caballo, I will be very interested in your progress, as I had a galah flew straight into my aerial on the way to work this morning and was wondering how difficult the job would be.
-Craig |
31-12-2011, 04:16 PM | #4 | ||
Next upgraded Mk1 Leopard
31-12-2011, 06:23 PM | #5 | ||
Token American
Hey crackrz, I'll hook you up in another thread. Funny, I went to fordmods and got some really good info there before you posted.
