Old 10-12-2011, 01:21 PM   #1
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Default AU tensioner reset
Hi all
I have reset my tensioner again (five times now) and the car still sounds to noisy. I have a video in my workshop build area. Any thoughts or comments of what I am doing wrong would be appreciated. Follow this link to the workshop build.
http://www.fordforums.com.au/showthr...35#post4024735
UK
Old 10-12-2011, 06:39 PM   #2
AU Mont
Default Re: AU tensioner reset
have you had a good look down inside the timing cover for broken chain guide/s?
AU Mont is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2011, 06:49 PM   #3
Stav
Smile
Stav's Avatar
Uncle Ken mate hi. Remove the rocker cover and check that the tensioner has the chain nice and tight not floppy.If its not tight then get another tensioner or maybe youve cracked a guide?
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 10-12-2011, 07:15 PM   #4
Uncle_Ken
Uncle_Ken's Avatar
Originally Posted by mongrelEF
Yeah, it's too noisy. Unless the tensioner's bouncing, it's tight enough. The noise in the video sounds more like a dry bearing; metal on metal. Have you tried spinning each pulley with the belt off and looking for a noise? Could be an alternator bearing?
*edit* Just read the rest of the thread The chain tensioner should have a half moon spacer between it and the chain guide; is that still there? They have been known to come off and disappear into the crankcase.....
MongrelEF posted this (many thanks) What does the spacer look like?
Uk
Old 10-12-2011, 09:14 PM   #5
AU Mont
hmm spacer?....2 prongs on the end of the tensioner assembly slot against the chain guide
so you havnt inspected for broken chain guides?
Old 10-12-2011, 10:57 PM   #6
Uncle_Ken
Uncle_Ken's Avatar
The part on the right? This is intact.
UK
Old 16-12-2011, 10:13 PM   #7
mik
mik's Avatar
how did you go Uncle Ken?
Old 17-12-2011, 04:05 PM   #8
Uncle_Ken
Uncle_Ken's Avatar
Still noisy. Talking it to Joe at Cresent auto on Tuesday. Will post an update then.
UK
Old 22-12-2011, 08:50 PM   #9
SSD-85
I ♥ EDM
SSD-85's Avatar
Would this problem cause a knocking noise under low rpm acceleration? (including backing off the throttle at low rpm)
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2011, 09:24 PM   #10
Uncle_Ken
Uncle_Ken's Avatar
Got the car back yesterday
So to recap...having reset the tenisoner many times it turns out the noise was not the tenisoner but a broken lifter !!!
Joe at Cresent motors at Liverpool replaced all the lifters and checked the throttle change I had done. So now I have to flush the oil a few times before the new lifters before quiten down.
The car felt good coming back from Liverpool to Castlehill. Flushed and Changed the oil/filter today..will postan sound grab on the weekend
UK
Old 23-12-2011, 01:37 AM   #11
mik
mik's Avatar
good your baby`s on the road again, i don`t think i have heard any mention of a broken lifter on an Au before, ah well long as she`s a goer again.
Old 23-12-2011, 09:23 AM   #12
Uncle_Ken
Uncle_Ken's Avatar
Yeah I had firsts
UK
Old 23-12-2011, 05:54 PM   #13
Uncle_Ken
Uncle_Ken's Avatar
Its sounding better already..see the two sounds bits in my build section
http://www.fordforums.com.au/showthr...92#post4044292
UK
