22-11-2011, 12:18 PM | #1 | ||
Hi all, can someone tell me what this hose is for? The arrow shows where it's snapped off from.
cheers James |
22-11-2011, 12:21 PM | #2 | ||
just a diff breather, not even needed unless you drive through deep puddles imo
22-11-2011, 12:34 PM | #3 | |||
Just another mock-up..
If the breather has broken as it has and gets blocked up it will cause pressure in the diff and seals to blow out and start leaking.. It's an easy fix though.. Cheers
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
22-11-2011, 01:27 PM | #4 | ||
Thanks for the quick replies.
Do you guys know where the breather hose goes to, is it hooked up to the carbon canister? |
22-11-2011, 01:34 PM | #5 | ||
EF XR6
shouldnt be building pressure at all, not a bad idea to keep it unblocked.
all it usually is is a fitting on top of the diff, with a rubber hose that runs down.
www.OzEcruisers.com.au
95 EF XR6: 5spd Manual, 3.45 LSD diff gears, JIM MOCK EXTRACTORS, 2 1/2" sports exhaust Short shifter, Pod filter in standard air box, 17 inch EL gt rims in gold. Lowered all round with king springs and pedders supsenion |
22-11-2011, 10:13 PM | #6 | ||
the other end goes under the back seat - just needs a dry air source and not a lot of ait either.
regards Blue |
23-11-2011, 08:58 AM | #7 | ||
Awesome, thanks for all your help.
