Old 13-11-2011, 07:47 PM   #1
Wink
Default Best cam suited for e-series i6?
Hello.
I seem to be getting good responses from this forum so thought I may as well ask another question.
What cam is the best suited for drag racing? without compromising too much on the street with a bit of.. you know what.
I am trying out a Wade 1673 with no vernier cam gear at the moment, an I am not really feeling any difference.. Then again I did buy this cam off a random, an claims it is billet. I measured the base circle as asked Wade, an he said that it wont require shims. I think I may need to remove the cam an measure the lobe an work out lobe lift an valve lift to make sure it is even the claimed cam.
As now, I tryed using the cam an I was doing worse off, then again, I couldn't get a good 60 foot time though i did expect my mph to be better at least, an if anything it was 1-2mph slower..
Wink is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2011, 07:58 PM   #2
dieseltrain79
Default Re: Best cam suited for e-series i6?
If your unsure of the cam specs , then how did you dial it in ???
Some cames come with advance or retard ground into the cam itself , others need dialling in .
When i had my modded EA , i ran a Herrod cam with adj cam gear on an EF engine .
Car went 14.0 @ 96mph .
1998 AU VCT Ghia - Stock as a rock - Wifes car
1991 Toyota Soarer TT - 11.72 @ 116.7mph
2004 Ford Escape XLT V6 - Family Ride .
dieseltrain79 is offline   Reply With Quote Multi-Quote with this Post
Old 15-11-2011, 12:30 AM   #3
Wink
I got the cam off a random bloke, I didn't dial it in, just used standard cam gear. Maybe to dial it in will make a bigger improvement.
Wow, you ran a 14 flat? What tyres? street tyres?
Also anymore modifications too your engine?
What were your diff gears? Manual?
My best time is 14.301 at 97mph on the 1/4 mile.
Old 15-11-2011, 07:39 PM   #4
dieseltrain79
Manual , 3.45 rear gears . Ported head , Herrod Cam , EF inlet , Match ported , Microtech ECU , car made 161.3rwkw 10 years ago ! And ran those times at the old track @ Eastern Creek .
Had the Tickford blokes asking questions thats for sure
Old 15-11-2011, 10:27 PM   #5
Wink
Yeah man that is quick. I wonder what the Herrod Cam was. You must of had the perfect 60ft time an got all your gear changes on the dot. I am plenty impressed.
Old 16-11-2011, 07:36 PM   #6
dieseltrain79
Thanks , was in an EA S GL to , so surprised a few back in the day .
60' was mid 1.8's and flat changed every gear .
Could never crack the magic 13 though .
Pretty spoilt for the last 5.5 yrs though with the Soarer ... Simple bolt ons and 11.8's for a daily really makes the EA look slow nowadays though , hehe .
Orignally i ran a Crow Cam but the herrod cam revved 500rpm more and picked me up 1.5mph and just over 1 tenth .
Old 18-11-2011, 03:53 PM   #7
Giant
Giant's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Organising Nulon to sponsor AFF.
I would be going for increased low down torque to get out of the hole.
Giant is offline   Reply With Quote Multi-Quote with this Post
