Old 02-10-2011, 09:22 AM   #1
Sox
RIP...
Sox's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: As recommended by Ropcher. Personifies the spirit of AFF.
Default Valving springs...
Morning gents,
The T3 engines are known to have dicky valve springs, the big question is, do the 220 donks suffer from the same problem.
I think I can feel a frag of valve float once it's spinning above 5500rpm, which is clearly not good, but I'm more concerned with them breaking, as per the T3 engines.
I'm not too interested in ripping heads off at the moment due to bent valves, damaged pistons, etc.
So, the million dollar question is have you guys with 220's busted any valve springs?
Oval Everywhere...
Sox is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2011, 10:13 AM   #2
SSD-85
Default Re: Valving springs...
Ive been told that the 220s can do the same thing. But Ive owned 3 of various kms & condition and its never happened.
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2011, 10:33 AM   #3
blueoval
Critical Thinker
blueoval's Avatar
I would say, if you intending on pushing the engine to that limit often Rick, you would be better off throwing in some heavy duty units in to be on the safe side. I can't answer for other v8 owners sadly.
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
Old 02-10-2011, 10:57 AM   #4
b2tf
not here much anymore
b2tf's Avatar
All of them can do it, just doesnt seem to be as common on the 'lower' engines like the 200's. I would replace them if you're worried about it, good insurance.
2024 F150 XLT
Old 02-10-2011, 11:10 AM   #5
FTe342
FTe342's Avatar
Have heard thru here of one 220 breaking a spring
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2011, 11:40 AM   #6
KR1STO
Just another mock-up..
KR1STO's Avatar
My next door neighbours XR8 ute, 200kw, broke a spring the other week..
Dropped cyl 7 IIRC..
Desire isn't driven by the heart, the mind or the wallet.
Desire comes from another place.
It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night...
see my car here:
Built my own TL50!!!
[SIGPIC][/SIGPIC]
KR1STO is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2011, 11:50 AM   #7
Sox
RIP...
Sox's Avatar
Ok, so it's not just a 'yeh it might happen' scenario, it has actually happened to at least a couple as far as we know.
That'll have to be next on the list I guess.
To you guys who have replaced, is the Crow kit P/N K6201 suited to the 220's as well, or are they just for the 250?
What else have you used, and what did you notice afterwards?
Oval Everywhere...
Old 02-10-2011, 12:33 PM   #8
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
Hello Sox, Replaced mine a couple of months ago after noticing the same symptoms as you. Went for Crow HD replacement which was a no fuss direct change out, ordered them direct from Crow ph (03) 9357 0469.
Part numbers below.
7738-16 (Springs), 11700-XR8 (Chromoly Retainers) and 11701 (Locks)
Cheers, Craig.
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 02-10-2011, 01:30 PM   #9
Whoosha
AU DIE HARD
Whoosha's Avatar
Number 2 broke on mine @ 70000 ks only replaced the 1 the rest have had no problems so far ,
Originally Posted by Riksta
Old 02-10-2011, 04:22 PM   #10
Sox
RIP...
Sox's Avatar
Part numbers below.
Yeh that's all the parts in the kit I mentioned above, so same as the 250.
Did the top end 'flutter' go away?
Oval Everywhere...
Old 02-10-2011, 05:01 PM   #11
CRAIGAU3220
Cat be Still !!!
Yes, sounds smooth as up top now...........Well as smooth as a factory built Windsor can be.
Cheers, Craig.
Old 08-10-2011, 11:53 PM   #12
troystanton78
IR84RD
Mine broke a inlet valve spring, just before redline, apparently its more common for the exhaust to go, replaced with yella terra, pretty sure they are the standard, no dramas since
3rd generation Ford man
01 AUII XR8 220kw White
troystanton78 is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2011, 06:23 PM   #13
aussiemart
aussiemart's Avatar
My 220 broke a spring at 100000k, got new ones through crow no probs.
aussiemart is offline   Reply With Quote Multi-Quote with this Post
Old 11-10-2011, 09:23 PM   #14
jmack
whats the going price for these and best place to get them as i dropped a valve in mine a while ago and been thinking about replacing them as when heads were repaired standard ones went back on
jmack is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2011, 10:31 AM   #15
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Speak to Justin at site sponsor tuffcarparts.com. It has been a while since I bought mine, but should be around $300 including postage. Don't quote me though.
Stu
2002 AU II LTD
2002 XR8 pursuit 250
auIILTD is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2011, 03:48 PM   #16
james22
With da Warlords
james22's Avatar
Morning gents,
Yep I broke a valve spring on No 7 (i think) a few years back. Didn't drop the valve thank god. Only had 115,000 - 120,000 kms on it too. Happened while moving the car in a workshop, so wasn't even under a lot of stress at the time.
Definitely recommend replacing them, especially if you have a few kms up
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear.
For Sale: Parachute. Only used once, never opened, small stain.
Windsor Warlords
AU III XR-8220
300+ rwhp of Manual fun
XR50T Ute - 300rwkw (give or take depending on the day)
james22 is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2011, 04:05 PM   #17
auIILTD
5.6L x 2 pilot
auIILTD's Avatar
Stu
Just spoke to Justin and bought a set for my 342 T3 stroker. Same price as quoted previously.
7738-16 $149 - Springs
11700/11710-16 $105 - Retainers
11701-16 $19.80 - Locks
Freight - $22.50
Total - $296.30
Freight was to Canberra.
Good luck
Stu
2002 AU II LTD
Old 12-10-2011, 11:09 PM   #18
t08
F6-557
t08's Avatar
Broke mine at 36000kms. Broke on the open road and didnt notice until i came to a stop. No damage though. Have done 91000kms now and no probs since. Had the 1 replaced under warranty.
t08 is offline   Reply With Quote Multi-Quote with this Post
