Old 22-06-2011, 10:26 PM   #1
aufreddy
Default Intake manifolds upgrade
Gday all,does any one know of a good upgrade for the intake manifolds in my au2 xr8?
aufreddy is offline   Reply With Quote Multi-Quote with this Post
Old 22-06-2011, 10:32 PM   #2
b2tf
not here much anymore
b2tf's Avatar
Default Re: Intake manifolds upgrade
Trickflow and Edelbrock seem to be the common choices but for the vast majority of applications the explorer with some port work seems to do the job.
RAM 1500
Old 23-06-2011, 02:06 PM   #3
BOTTLEDUP
Only worthwhile upgrade over the factory intake would be the Edelbrock RPMII, assuming of course the rest of the engine is near standard. Manifolds such as the Performer 5.0 or TFS Street Burner are no improvement on what you already have... The RPMII will make more peak power, but will lag behind your current intake up to 4000rpm.
BOTTLEDUP is offline   Reply With Quote Multi-Quote with this Post
Old 23-06-2011, 02:25 PM   #4
T3man
T3man's Avatar
Seriously? Is the SeriesII intake manifold on the 5.0L that good? That kinda surprises me - I know the T3 ones are excellent.
Old 23-06-2011, 02:32 PM   #5
BOTTLEDUP
Yes the 'Explorer' intake is a cast version of the tubular GT40 intake, and flows within 5cfm of it. The Performer 5.0 & Street Burner are good upgrades over the early 'HO' but you would not notice any gain over your existing intake.
The T3 intake is a great bit of gear, though a little hard to get hold of! :-)
Old 24-06-2011, 05:26 PM   #6
Boza
Boza's Avatar
So what manifold is on mt dec99 xr8 ute explorer or gt40
Boza is offline   Reply With Quote Multi-Quote with this Post
Old 24-06-2011, 08:14 PM   #7
CRAIGAU3220
Cat be Still !!!
CRAIGAU3220's Avatar
Explorer........Unless this is trick question and you have fitted a GT40 Intake.
CRAIGAU3220 is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2011, 10:25 AM   #8
InfernoSR
Sales Representative
InfernoSR's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: For research and posted write up on cooling system care and repair in AU.COM and offering help where possible
Would be pretty sweet if he did... but where is the rest of the GT40 engine to go with it??
InfernoSR is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2011, 11:11 PM   #9
aussiemart
aussiemart's Avatar
Many a dyno session has been ruled by the gt40/explorer, especially on a 5.0 that is street driven, as bottledup said there is losses under at least 4000 with all other manifolds ive seen tested even on a stroker.
aussiemart is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2011, 08:51 AM   #10
Cam
Stroking it...
Cam's Avatar
I'm running a trickflow street heat (now called street burner) on my Stroker.. With a Baby cam (blower cam) it makes 590nm@2800rpm / 300rwhp@5200rpm with a 2800rpm high stall.. Have been VERY happy with this manifold and it's 0-5500rpm rpm range makes it well suited for a mild weezor setup.. My setup still sees just under 500nm@5000rpm.. So nice flat torque curve.. But yes, there will be some losses of torque at lower rpm, but you can't have it all..
http://www.allfordmustangs.com/forum...rque-loss.html
Cam is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2011, 11:57 AM   #11
roberts
can you flip the manifold so the throttle body can face the other way on an exploder manifold?
roberts is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2011, 01:37 PM   #12
BOTTLEDUP
Yes it is reversable, it is already 'flipped' when used in our falcons.
Old 26-06-2011, 03:58 PM   #13
roberts
nice one, been trying to find that info for a while i thought it was looking at mustang photos. Would make intercooler piping more straight forward with a side mount supercharger and will look heaps cleaner too with the inlet facing the drivers side, battery in the tray/boot of course. Thanks bottledup.
Old 26-06-2011, 10:45 PM   #14
Boza
Boza's Avatar
Mate I genuinely don't know I've always had the earlier windsors eb and an ef I'm still learning with au's
