Old 20-06-2011, 10:55 AM   #1
FTe342
FTe342's Avatar
Default IRS Diff Ratio
I have a complete IRS cradle inc diff, drive shafts etc but not sure what it came from - possibly a Fairmont but not sure if 6 or 8 cyl. Don't know what Series it is either
The ratio label sticker is not readable but the metal tag on the filler hole says its high performance.
I'm hoping its a 3.45. Were there any other ratios ratios available?
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2011, 11:04 AM   #2
Jimmyd
Default Re: IRS Diff Ratio
Can't recall seeing a "High Performance" metal tag on an AU IRS - usually see this if anything
As for the diff ratio there will be two labels,
yellow one on the diff head,
white barcode one on the cradle,
Jimmyd is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2011, 11:12 AM   #3
FTe342
FTe342's Avatar
Thanks so much. Its leaning up against a wall so didn't see the cradle barcode sticker. It's a 3.23. The metal tag says High Performance SE approved oil to be used. So it may not even be a LSD?
OWN THE ROAD
Old 20-06-2011, 11:25 AM   #4
Jimmyd
Sounds like a single spinner V8 Ghia diff.
Easy way to check LSD or not - lock up the pinion flange and turn one hub. If the other hub turns in the same direction its a LSD, if turns in the opposite direction its a single spinner.
Old 20-06-2011, 11:40 AM   #5
SSD-85
Did any of the AU series V8 ghias/non-ghias come with LSD without it being a special order?
SSD-85 is offline   Reply With Quote Multi-Quote with this Post
Old 20-06-2011, 12:14 PM   #6
FTe342
FTe342's Avatar
Thanks again. Easier said than done cause the rotors are rusted up from sitting outside. Mate was going to use this to build a Tru Track for XR8 but ratio is wrong so no use. I notice it has different thickness driveshafts to my T3 diffs so may as well strip it and just keep the cradle.
What about the driveshafts - are they same for XR8?
OWN THE ROAD
