Old 23-05-2011, 05:59 PM   #1
fullysick1
more of an alternator
Default au wont fire
hi all i have a ford au fairmont on gas it wont start after stopping at shops turns over but wont fire can hear solenoids clicking when putting ignition on. oil light water light petrol light and volts gauge all stay iluminated while turning over any ideas
fullysick1 is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2011, 06:02 PM   #2
XRGhia
meh.
XRGhia's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Contributions in the technical arena.
Default Re: au wont fire
Is it out of gear?
If it is out of gear, Try moving the shifter from P to N, then see if it will crank.. Just run it quickly from P to 1 then back again.. then try starting it in P and N
If that works, then it's your inhibitor switch.. Cheap and easy part to replace..
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear
XRGhia is offline   Reply With Quote Multi-Quote with this Post
Old 23-05-2011, 06:16 PM   #3
fullysick1
tried it it n and p no difference still turns over and wont the inhibitor switch stop it from cranking
Old 23-05-2011, 06:42 PM   #4
rag top
rag top's Avatar
is it an egas, or has it had an aftermarket gas conversion?
Old 23-05-2011, 07:10 PM   #5
fullysick1
its aftermarket
Old 23-05-2011, 07:16 PM   #6
fullysick1
dont all the dash lights usually go off when turning over the fuel light is staying on even though the gauge is reading 3/4 full
Old 23-05-2011, 07:40 PM   #7
mik
mik's Avatar
any other symptoms , has it been running well prior to this?
Old 23-05-2011, 07:44 PM   #8
fullysick1
car has been fine wife said she jumped in tried to start it went to fire then stopped now just cranks over
Old 24-05-2011, 12:23 PM   #9
4ford
Since the conversion, is it now only able to run on gas...
If so, does it automatically switch to petrol for starting...
If you can switch to petrol, do so and try that...
Cheers...
4ford is offline   Reply With Quote Multi-Quote with this Post
Old 26-05-2011, 09:30 PM   #10
mik
mik's Avatar
got fuel in it? not uncommon for people to overlook stuff, i had a lady once ask for help with a flat battery, after dragging a booster battery and jumper leads 200 metres to her car, the woman had forgotten to put the tbar into park
Old 26-05-2011, 10:47 PM   #11
b2tf
not here much anymore
b2tf's Avatar
Has the interior light fuse blown?
2024 F150 XLT
