Old 09-05-2011, 10:55 PM   #1
Day-mow
rexnet
Day-mow's Avatar
Default taking out the Cross Member
hey guys. so im gonna do my sump gasket. and take out the cross member. i had a look in the how to but couldn't see anything that would help.
just wondering if anyones done it and if there are any tricks i need to know. have a bit of time yet. the project is happening may 27
MY06 WRX Build Not Bought
Collingrove Hill Climb- 38.79
Old 10-05-2011, 02:17 AM   #2
blownv8au
Pro Street Au Ute
blownv8au's Avatar
Default Re: taking out the Cross Member
could you just undo the engine mounts and jack the motor up as far as it will go and change the gasket. I'd do this with a one piece gasket but with 4 piece i just drop the sump. I won't be pulling out the crossmember to change the sump gaskets in either of my 5ls.
blownv8au is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2011, 11:29 AM   #3
blueoval
Critical Thinker
blueoval's Avatar
This is gonna be a b***h of a job getting it done on your driveway floor. You sure you are up to the task Damien?
"the greatest trick the devil pulled, is convincing the world he doesn't exist"
2022 Mazda CX5 GTSP Turbo
1967 XR FALCON 500
Cars previously owned:
2021 Subaru Outback Sport
2018 Subaru XV-S
2012 Subaru Forester X
2007 Subaru Liberty GT
2001 Subaru GX wagon
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1984 Datsun Bluebird Wagon
1975 Honda Civic
Old 10-05-2011, 01:10 PM   #4
Day-mow
rexnet
Day-mow's Avatar
Cars on jack stands. I have a ford mech helping me whose pretty sic at life. It's either engine out or x member out. Dave seems to think x member is easiest. I have faith in his decesion.
Old 10-05-2011, 01:30 PM   #5
blownv8au
Pro Street Au Ute
blownv8au's Avatar
fair enough, i would not have thought it would be that extreme to change a sump gasket on a six. It must be pretty tightly packed in there. Can you just lower the crossmember down to the ends of the bolts instead of completely removing it?
Old 10-05-2011, 01:48 PM   #6
blueoval
Critical Thinker
blueoval's Avatar
If you have someone in the know, it always helps. All the best with it bro
1967 XR FALCON 500
2018 Subaru XV-S
1991 EB XR8
1977 XC Fairmont
1990 EA S Pak
1984 XE S Pak
1982 ZJ Fairlane
1983 XE Fairmont
1989 EA Falcon
1975 Honda Civic
Old 10-05-2011, 07:12 PM   #7
Day-mow
rexnet
Day-mow's Avatar
I think plans gonna b.
Block and tackle the engine from shed roof to hold it. Undo engine mounts drop x member, power steering rack, sway bars and do it like that. He did heaps on ef/l's but none on au's. It'll sort
Old 10-05-2011, 08:39 PM   #8
Ford Falcon XR6
Ford Falcon XR6's Avatar
Hey mate i got to do mine pretty soon as it's got a bit of a leak if you could take a few pics of when you do it and post em that would be great.
Ford Falcon XR6 is offline   Reply With Quote Multi-Quote with this Post
Old 10-05-2011, 10:06 PM   #9
Day-mow
rexnet
Day-mow's Avatar
Hahahahahaha. Ill try remember. Front timing case is also coming off and changing that gasket to be sure to be sure its not gonna leak. Will try take pics.
Old 11-05-2011, 08:50 AM   #10
bartsau
bartsau's Avatar
Having replaced a complete front K frame / cross member I can tell you this is not a job to be taken lightly. However, if you are comfortable on the tools and in no great rush it is not too bad to do. You will as said need to drop steering rack, sway bar and a few other bits and pieces. I would be seeing if by un bolting the engine mounts you can get the clearance required that way as that would be much easier.
Rhys
Wagon Build
AU I Forte Sedan - No longer
Toy Car Build
