Site Support If something isn't working or you have a suggestion ( a nice one !! ) let us know here. |
12-02-2010, 01:58 PM | #1 | ||
Flairs - Truckers Delight
Afternoon all,
I was just wondering if there are vbulletin tags for strikethrough? If not, can we have this feature added/enabled? It comes in handy in many situations, like editing a reply when you misread the original post and want to make sure others don't make the same mistake, for example. Cheers & TGIF Mr Hardware
15-02-2010, 04:06 PM | #2 | ||
Chairman & Administrator
The tag for strike-through is s /s with the tag enclosed by [ ] brackets.
As in: The quick Cheers Russ
Observatio Facta Rotae
18-02-2010, 11:51 PM | #3 | ||
2006-2016: Regency Red 2000 AUII Ford Falcon Forte Automatic Sedan Tickford LPG "Millennium Falcon" Last edited by russellw; 24-02-2010 at 11:44 AM. |
24-02-2010, 12:58 AM | #4 | ||
So it seems to work in this thread
http://www.fordforums.com.au/showpos...6&postcount=14
2006-2016: Regency Red 2000 AUII Ford Falcon Forte Automatic Sedan Tickford LPG "Millennium Falcon" Last edited by russellw; 24-02-2010 at 11:45 AM. |
24-02-2010, 11:35 AM | #5 | ||
It actually shouldn't have worked here as the forums are not supposed to have HTML enabled and the <s> style tags are HTML. I've turned it off here so now they don't work. The BB equivalents use the [ s ] style tag.
I have fixed this now by adding a new code and it will also appear in the WYSIWYG editor as an icon. Use the square brackets. Cheers Russ
25-02-2010, 04:42 PM | #6 | ||
Excellent, thanks Russ.
Cheers!
02-04-2011, 12:49 AM | #7 | ||
I have also added a highlight text BB Code. The tag is hl /hl (enclosed by [] brackets) or you can use the icon on the Advanced reply box.
Sample: [ hl ] test text [ /hl] (without the spaces) this text is highlighted Cheers Russ
02-04-2011, 02:05 AM | #8 | ||
The custom buttons have also been added to the quick reply and quick edit boxes.
Cheers Russ
02-04-2011, 09:58 AM | #9 | |||
off in outer space
"Always be yourself... because the people that matter, don't mind and the people that do mind, don't matter".
