#31 | ||
XA coupe owner
I knew of a bloke that used to do this years ago, But it was stuff called "Bon Ami" that was put on a teaspoon, then held over the carby, reving the motor to slowly suck it from the spoon, it seamed to stop oil consumption and smoke for a while.
#32 | ||
LOL get someone to try this on an MPI E-series and see what happens.
#33 | |||
#34 | ||
___________
Won't the CAT get blocked from the ajax?
#35 | |||
#36 | |||
Hoon On The Rise
![]() Join Date: Mar 2005
Don't do it too manyh times, or you will do damage, but give it some throttle and let it backfire two to three times.... Makes a difference yes..... Glad it worked for you.
![]() ![]() FGX-XR8 Manual, BFII E-Gas, '11 GSXR 1000 - Love 'em!
FPV Tickford Club of NSW - www.fpvclub.com |
#37 | ||
I.B.S is a pain in d'***
Well ! What an interesting thread i have created. I honestly thought my mate was having a big lend of me.
My carby is poping and farting and flat spoting (carby fire i think is the correct term) im wondering if the Ajax would solve this? As for the banana skin in the diff i think you will find it works better with the banana only without the skin.
I DONT BELIEVE IN NOS.............but if its given to you free at the hospital well then ![]() |
#38 | ||
after this thread im also contemplating the moth balls in the fuel tank. now if i could just remember the ingredient that gives the zing then id go find a moth ball product with the most of it and whack it in the tank.
anyone remember if they used moth balls or powder on myth busters? |
#39 | ||
What happened on myth busters? i didnt see this.
#40 | ||
So do you guys think that the Ajax will also clean carbon deposits from the valves and ports etc? Or is that pushing it?
#41 | |||
Hoon On The Rise
Between that and a few good backfires, yes. You will notice the difference. Cheers
#42 | ||
Ich bin ein auslander
Moth balls are made of napthalene, not sure if there are any other additives
Growing old is compulsory, growing up is optional! |
#43 | |||
there is a thread somewhere about it. search for Myth Busters on AFF. |
#44 | |||
#45 | ||
Could that also be a timing issue if your carby is doing that?
#46 | |||
Engines not firing on all cylinders, she can stall on take off cause of it. Needs new plugs, points, carby overhaul and of course a check on timing! ![]() But i have other problems to worry about first, like getting the sound system installed :Reverend: :Reverend: :Reverend:
#47 | ||
Sound system is very important!
But mate in seriousness - if it needs those things like you said - Ajax nor swapping leads is going to magically fix anything dude. You are still gonna have plugs and points that are going to need replacing, timing to set, etc. |
#48 | ||
Yeh, true. But that means i have to prioritise! and thats NO fun
#49 | ||
Can someone please try this on an MPFI engine!!!
#50 | |||
#51 | ||
I converted my EL to CFI ;) HAHA :P no chance ill try it first.
