Old 29-12-2010, 09:12 PM   #1
DZFord
DZFord's Avatar
Default Driveshaft problem?
Backed out of the driveway today and had a small blob of thick greasy-oil sitting there. Looked under the hood and was greeted by this - driver's side driveshaft:
It's everywhere
I'm hoping to get under the car later and have a closer look. Thinking its just driveshaft / CV grease at this stage.
By the way, engine oil, coolant and brake fluid levels are all OK. No engine lights on. Idles fine.
Any opinions?
Old 29-12-2010, 09:48 PM   #2
marg99
Look for a tear in the drive shaft boot or loose clip on the boot.
If its torn replace very quickly or you can get contamination in the joint and need a new CV. Worth also checking its not the transmission housing seal where the drive shaft enters it.
Old 29-12-2010, 10:03 PM   #3
casabonka
You can call me Chris
casabonka's Avatar
thats identical to when I was changing the springs in my old lancer and we dropped one on the CV boot - after the next drive it looked the same inside...
'06 LS Focus Hatch
-2 1/4" Lukey Exhaust
-RDA Slotted discs/Greenstuff pads
-Rear Whiteline swaybay
-Lenso 18's w/Kumho rubber
-Tinted Windows
casabonka is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2010, 10:40 PM   #4
DZFord
DZFord's Avatar
Thanks for your quick replies.
Just got out from under the car. Looks like a tear in the inner CV boot.
Will put it in for a service tomorrow.
Old 30-12-2010, 07:13 PM   #5
DZFord
DZFord's Avatar
Just got back from Ford. They couldn't really find anything. They believe there may be a small tear in the CV boot (which can't be seen), which exapnds once it heats up.
Solution will be a CV boot replacement.
Old 30-12-2010, 07:26 PM   #6
20focus05
I wanna XR5
20focus05's Avatar
you only need a very small hole for the grease to be spun out.
get the boot replaced asap.
I hate how much mess it makes.
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 31-01-2011, 09:59 PM   #7
DZFord
DZFord's Avatar
Got this fixed up at Ford about a month ago. $373 for new boot inc. labour. Ouch!
Old 31-01-2011, 10:38 PM   #8
casabonka
casabonka's Avatar
i hope that included them cleaning up the remains!
'06 LS Focus Hatch
-Tinted Windows
Old 31-01-2011, 10:43 PM   #9
DZFord
DZFord's Avatar
Haha actually they did a good job of that!
