Tickford
Hi All
Some lowlife stole the only key to my AU3. I've since been to Ford and had a couple of keys cut (which work in the ignition and doors) but I need to get the BEM coded to the new keys. I'd like to avoid having to tow the car to Ford to have this done as I'd have to tow the car back which would prove pretty costly. Can anyone suggest a mobile service that can program the new keys to the BEM so I can get the car started? Thanks in advance
ED XR8 Sprint - 306ci SBF, GT40, Comp XE270, T5, 3.45 LSD AU T3 TS50 - 345ci SBF, AFR 185, Comp XE274, 2800 stall, ESS LE97, 3.45 LSD BA XT SZ Territory TS RWD TDCi |
not here much anymore
I dont think it can be done without using the WDS which only Ford have.
RAM 1500
Tickford
Bugger.
I have spoken to one mobile guy who believes he can do it, but won't be able to know for certain unless he tries. My tuner (XFT) has confirmed they can disable the Smartshield side of things, but I don't want to do this as a) I want to keep the security and b) I need to get things done like exhaust and fill/run in the transmission properly before I dyno tune the car.
Geelong FC 07, 09 & 2011
I don't know about mobile guys but some auto wreckers can reprogram keys and BEM modules. They did for me when i did my dual zone conversion.
2023 Audi A5 45 TFSI |
I'm interested in the answer to this question too.
When I was looking into it a while ago, I found that only Ford could do it - although that could well be something made up by Ford to make sure you go to them with your $$. How much did Ford charge you to physically cut the key? Do you just need the VIN and proof of ownership or do they need the car for that too? |
I drive way too much...
I got my new key cut and the old ones coded out of the computer by AAA Ability Locksmiths in jandakot. They took a portable machine out to the carpark to do the in-car programming, so perhaps they'd come to you for a fee or a carton?
http://maps.google.com.au/maps/place...67025447734408 It was $99 for a new key from there. Much cheaper than ford.
AUIII Straight LPG Done: BA XR6T Snorkel, K&N Panel Filter, EL Belt Cover, 2.5" Exhaust To Come: Extractors, Tran. Cooler, Lowering, High-flow Cat |
Tickford
A1 Locksmiths have said they 100% can code the transponder keys to my car without the original keys, $170.
I've book in for Monday, a mechanic mate is coming over to give it a go with his computer as it says it can communicate with Ford BEMs.
Tickford
My mechanic mate came over after work with his million dollar diagnostic computer, took us about 15 minutes and we successfully cleared the existing keys in the BEM and programmed the new ones.
So long as you have two new keys it's a pretty straightforward exercise.
Nice. Does your mechanic mate have a shop? Might come in handy for us Perth guys next time.
