Old 30-09-2005, 06:17 PM   #121
Sprint_ED
Sprint_ED's Avatar
yeah i was really supprised how it put me back in the seat for a 6 off the line, the feeling was like my car sitting at bout 3000 in 1st gear rolling then booting it, so it did make the diffrence, i dunoo how good useful its would be on say mine or an equivelant v8, but works wonders on the six
RIDE: Cobalt blue XR8 Sprint
MODS:Lowered, Paceys, Twin 2.25'' Exhaust By Hallam Exhaust, AFR 165's, Crane 2031 Cam, E-Series Edit, 180 RWKW
TUNED BY BLUEPOWER RACING DEVELOPMENTS 13.79 @ 102 Mph
Sprint_ED is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2005, 11:55 AM   #122
jonbays
TL40 Wagon?
I agree from driving useless AU Auto with his 2500rpm stallie this is a top mod for the I6 which feels so much better off the line.
On the V8 its a waste of time they have 2000-2400rpm stall converters stock. This is maybe why they have the infamous torque tags in the ecu and the sixes don't.
jonbays is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2005, 12:07 PM   #123
Casper
Contributing Member
Casper's Avatar
I just took mine for a 600km drive yesterday.... this is not a mod I would consider for cars that have a higher use factor than 200-300kms a week... economy does suffer. Great fun but you do notice it reving harder on hills etc even in cruise control.
Older, wiser, poorer.
Old 02-10-2005, 08:31 PM   #124
Stav
Smile
Stav's Avatar
What is the difference in fuel economy Casper?Mine is currently running pig rich.SO cant make a compare yet.
Stingray Car Security ph 0414445444
Single din radio fascias for fg to fgx fords Australia wide .
FG 1 2 and 3 gauge holder in stock now! https://stingraycar.com.au/shop/
Site Sponsor See Sponsor Stingray Car Security 😍👌✌
AU wagon 6 14.241@96.75 1/4 mile sold.Octane fg xr6 turbo!! 12.312 112.21 mph home tune f6 injectors gone ..now in nitro fgxr6t ready to go again
Old 03-10-2005, 08:52 PM   #125
INJECTED_250
Custom user title
INJECTED_250's Avatar
But on highway speeds.... wouldnt it still sit at the same speeds / rpm because there is still converter lock?.... or is that gone?
INJECTED_250 is offline   Reply With Quote Multi-Quote with this Post
Old 03-10-2005, 09:08 PM   #126
EFFalcon
Last warning
EFFalcon's Avatar
converter will unlock if the load excedes what is required, and this is on hills..
and would be more likely to happen with a higher stall.
i can't work out why yours is running rich useless?
or is there a genuine reason for it?
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 03-10-2005, 09:30 PM   #127
Stav
Smile
Stav's Avatar
I know what the problem is.But cannot post it here.If you wish to know pm me.It is just running rich at idle.The rest feels good.But it is enough to foul the plugs and cause less than optimal ignition.
Old 03-10-2005, 09:40 PM   #128
Casper
Contributing Member
Casper's Avatar
EFFalcon is 100% correct. The lockup is still there but it has its limitations. As John said, it will unlock if the load/throttle exceeds parameters.
Old 04-10-2005, 12:16 AM   #129
Headsex
headsexTuned
Which can be changed in the edit :>
We were experimenting with locking the convertor all of 3rd gear, and it was.. a weird manual feeling....
d.
Headsex is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2005, 07:00 AM   #130
Casper
Contributing Member
Casper's Avatar
d.
Good way to kill a 1/4 mile time.. hit 3rd and watch the revs die in the *** as the converter just locks up immediatly... its bad enough as it is now :1syellow1
Old 04-10-2005, 10:22 AM   #131
xr8ute
Back on the road
xr8ute's Avatar
Thats crap...you're just not making enough power yet Casper ;)
When are you fitting that blower...?
AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute
5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor.
Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash.
xr8ute is offline   Reply With Quote Multi-Quote with this Post
Old 04-10-2005, 10:25 AM   #132
Casper
Contributing Member
Casper's Avatar
No argument here, no where near enough power..... not even close
Soon as you crate yours up and send it to me.... I can assure you it will get a loveing home and a VERY hard life. :Up_to_som
Old 07-10-2005, 02:38 PM   #133
Headsex
headsexTuned
Yes ........ We can also Unlock the convertor in 3rd when your at WOT
The Auto trans functions of the AU are pretty much sorted in this sence..
Danny.
Old 07-10-2005, 02:56 PM   #134
EFFalcon
Last warning
EFFalcon's Avatar
if i whack mine into 3rd (on thie shifter) it will lock up.
if i put it into D (on the shifter) it will stay unlocked.
are AU's the same?
Old 07-10-2005, 02:59 PM   #135
Headsex
headsexTuned
are AU's the same?
I will have to check my AU.. But i know with the BA, if you have it in ESS mode, and 3rd gear is selected, It will lockup right at the top end of the scale @ WOT.. however, if its in Drive, it will switch to 4th gear, and then lockup..
Let ya know tonight what my AU does
danny.
Old 08-10-2005, 07:27 AM   #136
Casper
Contributing Member
Casper's Avatar
:... I have a big, shiny switch in my glovebox that allows me to do exactly the same thing. Converter lockup is a VERY simple thing to override :P
And yes, even selecting gears manually in my AU 3rd will lock up in the upper rpms.
Old 08-10-2005, 10:03 AM   #137
jonbays
TL40 Wagon?
Third gear lock up is only available in third not Drive. So as casper says on the strip use drive and power button which stops the lock up occuring too early and spoiling the run.
Third lock up is for decellerating downhill not for the strip!
Old 08-10-2005, 05:32 PM   #138
xr8ute
Back on the road
xr8ute's Avatar
Keep away, shes all mine....lol
