26-12-2010, 10:54 PM | #1 | ||
Hey Hey,
My I6 AU2 auto sedan is starting to vibrate. It does it at 90kph in 4th with the torque converter locked. Its a vibration like the rears wheels are out of balance but it pulsates. Cant feel it through the steering just every where else. It doesn't do it in 3rd with the torque converter locked just 4th. That rules out wheels and diff. So im thinking gearbox is starting to show its age ? 30,000km ago i flushed all the fluid and fitted an oil cooler so the fluid is still reasonably good. Opinions ?
AU XLS. |
27-12-2010, 09:52 AM | #2 | ||
Could be the tail shaft is out of balance, or the uni joints are shot, also the bush in the back of the gear box could be stuffed,
There was a thread on this some where with the same problem
Welder/Fabricator at Beaudesert Exhuast Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors |
27-12-2010, 11:01 AM | #3 | ||
I'd near put money on a rear uni, Checking to see if there's play won't tell you the story either.
I think its lost lube in one of the caps, usually felt during mild acceleration & higher cruise speeds. Solidified grease & sometime rust take up all the spare space in the effected cap so checking for play won't show it up. |
27-12-2010, 02:15 PM | #4 | |||
AU XLS. |
27-12-2010, 02:21 PM | #5 | ||
my series 2 xr6 the tailshaft uni`s were getting a bit of play in them at about 130000 k`s, i did mine early last year iirc, definately worth checking if they have`nt been done.
27-12-2010, 02:41 PM | #6 | ||
Will have to wait till Wednesday so i can put it on a hoist.
AU XLS. |
28-12-2010, 10:50 AM | #7 | ||
joshes car had some bad vibrations and was using a tonne of fluid, turned out to be the bearing/bush in the back of the gearbox
otherwise if its the box i still have my built gearbox here waiting for sombody to buy.. yours for only $750 shift kitted, extra clutch packs and all that fun stuff
30-12-2010, 10:18 AM | #8 | |||
It could well be something more serious, but that still sounds like a uni. 3rd gear generates more torque & will force the uni past its tight spot. 4th gear converter locked the engine has less mechanical advantage over the drive line + its rpms are pulled down so the actual force its exerting on the tail shaft is less, this is when a crook uni will start vibrating. No real way to check them either, even on a hoist, they will look & feel fine. Only real way is to pull them apart & of course for the cost of them you then just turf em & fit new ones. |
30-12-2010, 07:49 PM | #9 | ||
The vibration went away but its back again.
AU XLS. |
30-12-2010, 09:07 PM | #10 | ||
Ok try this out.One of my utes was doing this.Turns out the thermo fan had stuffed itself,this resulted in the trans fluid getting hot and the same thing you have decribed happening.It was the low speed fan,not the AC one.
If you have some body that has access to computer testing equipment id have that looked at. |
30-12-2010, 09:49 PM | #11 | ||
Fans work fine, They **** themselves about a month ago and have brand new ones fitted and working fine.
I'm thinking the tail shaft like people have suggested or the box is packing it in.
AU XLS. |
31-12-2010, 04:51 PM | #12 | |||
Honestly i would look in this area too.Take note if it is doing it when it either hot or cold.Mine was really bad after getting off the freeway and then driving on local streets. |
31-12-2010, 05:01 PM | #13 | ||
Does it cold, hot all the time.
AU XLS. |
04-01-2011, 02:19 PM | #14 | ||
Went to my mechanic friend today and put it on the hoist. My torque converter is stuffed.
AU XLS. |
04-01-2011, 02:43 PM | #15 | ||
Critical Thinker
Get the stock converter stretched out a few hundred rpms while its out. Its a cheaper form of a stall converter.
"the greatest trick the devil pulled, is convincing the world he doesn't exist" 2022 Mazda CX5 GTSP Turbo 2018 Hyundai Santa Fe Highlander 1967 XR FALCON 500 Cars previously owned: 2021 Subaru Outback Sport 2018 Subaru XV-S 2012 Subaru Forester X 2007 Subaru Liberty GT 2001 AU2 75th Anniversary Futura 2001 Subaru GX wagon 1991 EB XR8 1977 XC Fairmont 1990 EA S Pak 1984 XE S Pak 1982 ZJ Fairlane 1983 XE Fairmont 1989 EA Falcon 1984 Datsun Bluebird Wagon 1975 Honda Civic |
04-01-2011, 03:59 PM | #16 | |||
AU XLS. |
04-01-2011, 05:02 PM | #17 | ||
Critical Thinker
Thats not bad at all. Make sure you post up the pics when you get it done.
10-01-2011, 11:54 PM | #18 | ||
How did he confirm it was the converter? I had the exact same symptoms as you, was told it was my converter, spent $900 on a semi-recoed box to find out it was my oxygen sensors.
I had identical pulsating symptoms @ converter lockup and it was my oxygen sensors leaning out the mixture. I discovered this by watching my trip computer and whenever I would get the Pulsating vibrations my instant l/100km would drop considerably, and then rise again when the vibrations went away. If I disconnected the battery and reset the ECU the problem would seem to fix itself for a couple of hundred K until the ECU relearnt it's previous bad readings. Drive the car with your Oxygen sensor disconnected just to double check this isn't the problem.
Formerly LV Focus XR5, AU Fairmont Ghia V8 & EBII Fairmont I6. Now...... 2012 FG MK2 XR6 Turbo - Manual & Luxury Pack - 302rwkw 2019 Escape St-Line |
11-01-2011, 11:56 AM | #19 | ||
Flairs - Truckers Delight
sd1800, i can see your concern, but a busted o2 sensor on an I6 doesn't display the same behaviour as one on a V8.
11-01-2011, 02:10 PM | #20 | |||
Resident AFF detailer
How do they actually do it? I'm not very mechanically minded, only when it comes to detailing!!!
11-01-2011, 02:22 PM | #21 | |||
Critical Thinker
To modify a stock stall, they open up the guts and flatten out the fins in the converter I believe. Meaning the engine has to rev a bit harder to get the converter to move hence the stall converter effect. At least I think thats they way its done. I have heard there are still benefits of getting a small stall fitted to even a mildly modified engine. The 2400rpm stall Im getting is second hand from a member I know of so I will be saving more cash, but for the extra 400rpm over stock it will help my off the line take offs and launches no end. Should also limit the amount of bog I get down low off the lights too. This then equals a bit more than before. haha Have a look at what you may be up for for an off the shelf item. TCI http://www.compperformancegroupstore...ry_Code=SNSCNV JMM http://www.jimmockmotorsport.com/html/whats_new.php Dominator http://www.dominatorconverter.com.au/streaker.html
