23-11-2010, 02:30 PM | #1 | ||
Hi guys
For the past 2 days been struggling to take my exhaust off, its a custom sports exhaust. the problem is, its a 2 peice exhaust and i cant seperate it at all. the rear part of the exhaust is connected to the mumffler, and held by a clamp, i unbolted the clamp and tried to take it apart, but it wont move. Also all bolts and rubber holders have been removed. is there another way that this can be done? thanks |
23-11-2010, 02:42 PM | #2 | ||
Petro-sexual
Lots of swearing, jiggling, swearing, yanking and swearing.
Then get a hack-saw/angel grinder/oxy torch (careful of fuel tank) and be done with it, and enjoy a celebratory beer afterwards. |
23-11-2010, 02:49 PM | #3 | ||
meh.
with the AU wagon that we have needed its exhaust replaced, due to the fact that the oxy torch didn't work that the exhaust place guys own (the au stays stock) they undid the clamp mentioned but left the hangars in and then kicked the tip from side to side until they could pull it out.... it worked bloody well and thats how im also going to remove the exhaust on the EF for a new sports exhaust
23-11-2010, 03:05 PM | #4 | ||
haha, theres never a time ive worked on a car without swearing.
i need the exhasut so i can use it on my other car, so i dont really want to start chopping it. |
23-11-2010, 03:07 PM | #5 | ||
xrghiawagon - i might give that a try, so leave the muffler bracket on and kick the back end of it?
23-11-2010, 03:08 PM | #6 | |||
Petro-sexual
Lots of back and forth and up and down wiggling then and it should eventually come apart. |
23-11-2010, 03:10 PM | #7 | ||
meh.
yeah... just leave all the brackets and hangars on and then try to kick it from side to side
23-11-2010, 04:29 PM | #8 | ||
rexnet
I always just used the angle grinder. Great invention they are. Not great for re using it tho unless u want it chopped.
23-11-2010, 04:31 PM | #9 | ||
It will be a bugger but with a lot of wiggling and up/down and sidewards movement should see it come off. As said above this is the best method.
I also used plenty of WD40/RP7 and this seemed to help heaps as there was a carbon build up on the inside which it was grabbing on. Also, if you plan on using it again you will most likely struggle to get them back together again as when it was done originally the clamp will have squashed the pipe so it may not go all the way back in. I had this problem doing the same thing and my mechanic struggled even with an oxy torch to get it back in right. Good luck, Rhys
AU III Forte wagon - V8, 5spd man, lowered, 18" Honeycombs, Stock diff rebuilt with TruTrac LSD, Leather Ghia interior/dash, custom twin 2.5" into single 3" exhaust. Wagon Build AU I Forte Sedan - No longer
Toy Car Build |
