Hey Guys,
I was driving home in my LT Ford Focus aka Ping Crosby. Lately its been diagnosed with a clutch/transmission issue with only 40 000km on the clock. My service provider has said that apparently its a wear and tear item, yet I don't ride the clutch :( When going up a fairly steep hill in third, I suddenly lost all power and it even struggeled in second gear. Its never done that before. Meanwhile the bottom sounded like it would fall out of the engine ![]() When I did a brief diagnostic check this afternoon the computer came back with the following error: DTC #01 E196 - does anyone have any idea what that code means. I'm a little annoyed to be honest. At the last service the Ford mechanic said that there was no errors present on the computer ![]() Help would be greatly appreciated. Cheers L42B ![]() |
Can't help you with the exact problem, but this is supposed to be the message...
E196 (U2196) Invalid data for engine RPM (Invalid CAN message) Taken from a list on this link below... http://www.fordwiki.co.uk/index.php/...iagnostic_Mode
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. ![]() Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
Hi mate sorry to hear that your focus is misbehaving.
What In Focus says is the same as what ive read Here is some more interesting info that may help Your main codes begin with P0000 to P1000 - EOBD codes P1001 to P1918 - Ford manufacturer codes C - Chassis codes B - Body system codes U - Unidentified communication codes This site is good for codes aswell - http://bba-reman.com/content.aspx?co...rary_obd2_eobd I found in a dealer service training manual that the focus has a EOBD system that monitors the cars systems. It comprises of 5 monitors. 1. Comprehensive component monitor (CCM) for emission control components. 2. Combustion misfire monitor 3. Heated oxygen sensor (HO2S) monitor 5.Catalytic converter efficiency monitor It sounds like its comming from the combustion misfire monitor. You will have too take it to a dealer & get them to fix the problem & do a dealer test cycle (DTC) & reset the Keep Alive Memory (KAM) which affects how the car runs due to its adaptive trim tables (self-learning tables) |
So what would cause the engine to combust badly and misfire? Everyones quick responses have been greatly appreciated.
L42B ![]() |
Its hard to tell what the exact problem is. It could be anything from spark plugs to fuel systems or even something electronic.
With all of these diagnostic systems that modern cars have. My suggestion would be take it to a dealer or someone who can use these systems to correctly diagnose the problem otherwize its a bit of trial & error & guesswork. You will still need to take it to someone who can do a "dealer test cycle" because once the fault has been rectified, the fault memory must be cleared. After this all of the monitering systems will then have to be tested to make sure everything is fixed during a drive cycle. If this isnt done it will not delete a rediness code that will trigger the (MIL) emmision control malfunction indcator lamp & tell you that something is still wrong. I know it sounds complicated but this is all to make sure the systems are fault free & the car runs properly. |
Well the problem was found. There was no oil in the engine
![]() Called 13 FORD to keep the service provider on there toes ![]() Seriously though, who would have forgotten to top up the oil when it went in for a service ![]() Cheers L42B |
wow its locky the motor didnt cease, just curious was the car overheating at all?? with the lack of oil & did a light come on for low oil pressure
