Old 20-05-2010, 12:05 PM   #1
dabrowski_1
Default Hard to start when warm
Hey guys,
thought i'd post an issue i've been having with my 07 LS Focus zetec.
When the engine is warm/hot (only when warm or hot) i cant seem to start the car unless i pump the accelerator a few times while the engine is turning over. It wont fire up unless doing so.
No warning lights appear, no strange sounds, and runs fine after it turns on. Got me thinking that maybe its a sensor that is faulty when warm. Cold starting is fine, and required no accelerator to get going. Definently not normal as sometimes the engine will shutter until the rev's stabilise.
car has 59,000k's, but have noticed it for the past 15-20,000k's intermediately.
any ideas?
dabrowski_1 is offline   Reply With Quote Multi-Quote with this Post
Old 21-05-2010, 02:16 PM   #2
dabrowski_1
anyone?
Old 21-05-2010, 07:40 PM   #3
casabonka
You can call me Chris
casabonka's Avatar
Hey mate,
I have had this happen a few times, but not just when it was cold.
Not sure if there is an issue/fix tho, but It always runs fine afterwards
'06 LS Focus Hatch
-2 1/4" Lukey Exhaust
-RDA Slotted discs/Greenstuff pads
-Rear Whiteline swaybay
-Lenso 18's w/Kumho rubber
-Tinted Windows
casabonka is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2010, 11:42 AM   #4
oblivion
I have this problem with my 06 Ford Focus..... Sometimes it wont start when its cold, and sometimes it wont start 5 mins after I have been driving it and sometimes it will stall (started doing this at 40,000km)... For me its a faulty fuel pump and sensor
oblivion is offline   Reply With Quote Multi-Quote with this Post
Old 09-06-2010, 12:46 PM   #5
jumbuck
I am no expert but my guess would be fuel pump. Or fuel might be vapourising in the line when hot.
jumbuck is offline   Reply With Quote Multi-Quote with this Post
Old 11-06-2010, 08:08 AM   #6
20focus05
I wanna XR5
20focus05's Avatar
I have 05 LS had thias issue since nearly new, hot, cold just anytime it may not start.
I use the anti flood mode (full accel while cranking) let foot off just as it starts.
same here no codes, ford found no faults and I have been to lazy to do some of my own diagnostics!
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 12-10-2010, 11:25 PM   #7
dabrowski_1
finally jumped back on this forum and saw ur posts. Thanks for the info!
Old 13-10-2010, 09:52 AM   #8
MaN|aC
My fiance used to have an 07 zetec
AS said above, full accelerator until it ticks over and you shouldn't have any further problems besides having to do this.
PITA but it does work.
It has to be fuel system or a sensor not showing the right amps. Either way, hard for Ford to actually diagnose.
MaN|aC is offline   Reply With Quote Multi-Quote with this Post
