Old 20-09-2010, 06:13 PM   #1
sic 40t
Question engine missing
hi got a 2003 focus i got a miss on number 1-4 lead no spark changed the coil pack still the same changed plugs no good any one known please help
sic 40t is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2010, 06:35 PM   #2
fordmondeoman
are u saying u have no spark on cyl 1 and 4 or no spark to any of the plugs. if its all of them then i would say ur crank angle sensor is playing up, or worse ecu.
if you have cyl 1 and cly 4 with no spark and u are sure that cly 1 and 4 coil and plug are fine, i would check the wiring to the ecu, if ok then possibly the ecu is not sending out the signal and would need replacing. Other thing to check is have you un-done a earth wire or has it high resistance ect. most coil packs will have a earth to the body some where hope this helps
2010 Mondeo Zetec TDI
fordmondeoman is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2010, 07:27 PM   #3
sic 40t
no spark to 1-4.put new coil still no good plug are new
Old 20-09-2010, 11:02 PM   #4
Mad_Aussie
what-tut-tut-tut
Mad_Aussie's Avatar
So you're saying that all four aren't getting spark?
Have you actually checked that there's no spark? Taken a plug out and checked that its firing? Are you certain its not a fuel issue?
Mad_Aussie is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2010, 06:26 AM   #5
fordmondeoman
sounds to me that the crank angle sensor isnt working, if the injectors arnt clocking on and off then i would be about 95% sure thats what it is
Old 21-09-2010, 07:26 PM   #6
More revs
Is it a diesel?
More revs is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2010, 09:00 PM   #7
sic 40t
not all 4 just 1 and 4 clylider asfor rest i have taken the plug out no firing getting fuel
Old 21-09-2010, 09:24 PM   #8
sic 40t
Originally Posted by More revs
Is it a diesel?
diesel? no way
Old 21-09-2010, 09:48 PM   #9
casabonka
You can call me Chris
casabonka's Avatar
its usually the last place you look...
'06 LS Focus Hatch
-2 1/4" Lukey Exhaust
-RDA Slotted discs/Greenstuff pads
-Rear Whiteline swaybay
-Lenso 18's w/Kumho rubber
-Tinted Windows
casabonka is offline   Reply With Quote Multi-Quote with this Post
Old 23-09-2010, 06:49 AM   #10
fordmondeoman
i cant remember does that engine have coils for each cyl or does it have 2 coils 1 for two cyl , sounds like possibly ur ecu may have died
Old 25-09-2010, 09:28 AM   #11
20focus05
I wanna XR5
20focus05's Avatar
I'm sure these run a single 4 post coil pack.
think you need the ecu ignition I/O checked or get a secondhand ecu and do a swap and see if that works.
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2010, 02:53 PM   #12
sic 40t
ecm died getting fixed for 450 thanks
