19-09-2010, 12:24 AM | #1 | ||
When I'm going at low speeds (like when reversing out or driving up a driveway), there is a squeak coming from what seems like one of the wheels. Now I if that's the case I don't know how to fix it (probably simple), worried about spraying anything one the brakes. Any suggestions?
19-09-2010, 12:27 AM | #2 | ||
Just another mock-up..
hand brake....
does it sound like its coming from the rear..? Actually, what kind of a sueak..? Does it only happen over bumps, or just as you're rolling along...? IRS or live axle...?
Desire isn't driven by the heart, the mind or the wallet. Desire comes from another place. It's created by the smell of burnt fuel under full throttle and the look a car gives you when you're washing it alone at night... see my car here: Built my own TL50!!! [SIGPIC][/SIGPIC]
19-09-2010, 12:36 AM | #3 | ||
Thanks KR1STO, its got live axle and happens when im rolling along, not over bumps. Yea I THINK it might be coming from the rear.
19-09-2010, 12:38 AM | #4 | ||
no worries...
first check the hand brake mate.. quite a common problem.. (get it adjusted or parts replaced if need be) next thing to look at would be rear wheel bearings...
19-09-2010, 12:43 AM | #5 | ||
I'm not sure how to do that, would even know where its exactly located to be honest. How much would it cost for a mechanic to check that all?
19-09-2010, 06:14 AM | #6 | ||
When in doubt, GAS IT!!
Do you regularly drive on a dirt road, if so it might well be the bushes. The fine dust gets between the rubber bush and metal and it'll never go away, except in the rain. Only fix for that is to change all the bushes. My Fairlane has a front end squeek that bugs me and the wagon is front AND back. Once I move back home and off of the dirt roads I'll change them all.
Bushbasher
19-09-2010, 09:50 AM | #7 | ||
Flairs - Truckers Delight
I had an annoying squeak in one of my cars years ago
i ended up dumping her, problem solved
19-09-2010, 10:09 AM | #8 | ||
hahahaha
19-09-2010, 10:37 AM | #9 | |||
19-09-2010, 11:29 AM | #10 | ||
pull on the handbrake gently till you feel it starting to load up while moving off in drive (1ST gear) for a couple of seconds if the squeek disappears............ put money on it its the handbrake shoe/s out of alignment .
19-09-2010, 12:03 PM | #11 | |||
Resident AFF detailer
No longer an 'active' detailer. |
19-09-2010, 04:29 PM | #12 | ||
app diesel mechanic
my au has that squeak to. the handbrakes gotta be nearly vertical to work. gotta adjsut it but keeps skipping my mind. and i drive on 16 kms of dirt road everyday.
my au's got all new bushes in the rear and it still happens so prolly handbrake. |
19-09-2010, 04:34 PM | #13 | ||
More money would be great
On the BAs, you must check the rear left wheel. Take it off, undo the caliper and rotor and the mechanism is probably seized like mine was.
NOTHIN' AT THE MOMENT! |
19-09-2010, 05:41 PM | #14 | ||
hmm, went and checked it before, seems like its gone, but maybe thats because i went for a long drive earlier on in the day????
19-09-2010, 05:56 PM | #15 | ||
im having the same problem. pretty sure it started happening when i gutter mounted from doing skids. have you been hitting any gutters lately?
19-09-2010, 06:28 PM | #16 | ||
nope, havn't been hitting any gutters, its gone for now, hope it never returns again, if it does, then I'll probably just live with it, no big deal
