08-05-2010, 11:16 PM | #1 | ||
Hi all, i would like to add a factory clock into my au1 Forte and was wondering if there is much involved in wiring and the plastic surround?
thanks. |
08-05-2010, 11:24 PM | #2 | ||
I wanted the same thing when in my 2000 S1 Au when it was just 1 year old.
Took it to Ford, bought the clock for $47 and left it with them. 8 hours later the clock is still sitting on the seat and their response was that the Forte did not have the proper wiring for the clock so it cant be done. They suggested an Auto electrician could make the loom and make it work but it would void my warranty. They did say however, that early AU1's, already had the loom there, ready to use, but it was deleted lator on in the first series. The place where the clock goes, just clips out. You could remove it and have a look to see if the wiring is there. If it isnt, you could probably get the correct loom from the wreckers. It is all plug and play with the correct loom. |
08-05-2010, 11:54 PM | #3 | ||
i just noticed there is a small removable cover where the clock sits, i popped it off and it is moulded for the clock to fit, will have to wait till morning to check if there are any spare plugs in there.
thanks. |
10-09-2010, 11:00 PM | #4 | ||
Travis - 1999 Ford AU S1
Would anyone know if the '98 models would have the loom? I've tried looking in the past, but haven't had a massive look for it. Cheers.
10-09-2010, 11:08 PM | #5 | ||
Lost Boost Gained Class
my dec 98 has the loom there for it so i fitted it u must get a S1 clock with the black back with orange text
2006 BF Fairmont Ghia
2001 AU Falcon |
10-09-2010, 11:11 PM | #6 | |||
10-09-2010, 11:22 PM | #7 | ||
mine was looped up at the back i just pulled it and it come up
2001 AU Falcon |
10-09-2010, 11:32 PM | #8 | |||
11-09-2010, 11:28 PM | #9 | ||
My AU doesn't have the wiring for it. I do however have the loom; would it be as easy as running some wiring to the memory wire in the stereo to keep track of the time and then to the ground and to the positive?
12-09-2010, 10:14 AM | #10 | |||
AU Falcon Man
hope that helps you wire it up... Cheers Cam
2015 SZ MkII Ford Territory TS Aero Blue, RWD Petrol, Standard Sat Nav. 2013 TF Ford Kuga Ambiente Panther Black, AWD, 6 Speed Auto, 1.6lt ecoBoost Turbo Petrol. Was 2012 FG Mk2 Ford Falcon XR6 Swift Green,6 Speed Auto, Stock... 2001 AUIII Ford Falcon Forte Genuine T2 TS50 bodykit, 18" BF Cobras, Boge and Eibach Suspension and Complete AU2 Fairmont Ghia Interior 1994 EF Ford Fairmont Gun Metal Grey, Lumpy Straight 6 |
12-09-2010, 11:16 AM | #11 | |||
12-09-2010, 11:52 AM | #12 | ||
my august 98 has the loom for the clock it was tucked back and taped up , the loom should be there , hope you find it
12-09-2010, 12:10 PM | #13 | |||
12-09-2010, 07:34 PM | #14 | ||
when i first had a look i didnt think t was there , it was up the back ,
took the radio out and the ash tray undid all screws and then unclipped the facia , took the tape off and then pulled the loom forward , only problem was that i thought a s2 clock would fit , but they have different plugs , still havnt got a series 1 clock , series 2 clock for sale pm me if anyone is interested , $10.00 plus post |
12-09-2010, 07:36 PM | #15 | ||
btw what year and month is your S1
12-09-2010, 08:43 PM | #16 | ||
AU Falcon Man
i just wired up my old clock in my dads rodeo, got it working same as factory
black - earth yellow/black = constant 12v purple/red = either illumination or ignition (cant remember) white = either illumination or ignition (cant remember) the clock worked with just the constant and neg were plugged in but the light wouldn't work unless both the others were connected edit, thats on a S2/3 clock, i assume a S1 is the same Cheers Cam
