hi guys... i want to network two computers at my house, and i don't know which type of cable to use (i'm connecting one network card directly to another)
anyone know much about this? cheers
2003 BA XT Wagon, I6, 4sp Auto, Dual Fuel, Prins Autogassystemen VSI LPG RIP: EA S MPFI 5 speed sedan w/exhaust, LSD, tint, 225's, DBA Golds, EL twin thermos, dual fuel and fluffy dice ; Stolen, recovered and written off, 7th April 2007 |
#2 | |||
beep beep
Yeah either using a crossover cat 5 cable or get wireless and use peer to peer networking
Nothing to see here, move along, move along... |
Undergraduate EB Operator
ye be need what is called a Crossover cable, these can be bought very cheaply just about anywhere, connect the two together set up your ip's within the same range, set the same workgroup and you should be able to start sharing.
Simon ----------------------- 04 BA Xr6 ... now with carpark dints ![]() ----------------------- |
#5 | |||
cheers
2003 BA XT Wagon, I6, 4sp Auto, Dual Fuel, Prins Autogassystemen VSI LPG RIP: EA S MPFI 5 speed sedan w/exhaust, LSD, tint, 225's, DBA Golds, EL twin thermos, dual fuel and fluffy dice ; Stolen, recovered and written off, 7th April 2007 Last edited by luke; 19-09-2005 at 11:31 AM. Reason: forgot to say thanks |
#6 | |||
Same workgroup ! Same Subnet ! Different IP! If you have XP2 service pack 2 you'll have to setup the firewall. Do a few more checks before racing back to DSE and abusing the goose with pimples. DSE usually have red end covers on their overpriced crossover cables. |
Posts: n/a
Yar, if you think your gonna ever get more than 2 computers next to each other, buy yee a hub , 25$ from ebay and enjoy 100mbs connection. Otherwise yee bee needing wireless network card.
beep beep
If you had 1Gbit cards, most of them support MDI/MDX connections which means that you could use a patch cable. But otherwise 100Mbit you will need a crossover.
while ye all be on the subject im havin troubles settin up my ad-hoc wireless connections between me laptop and me home computer
apart from the two network cards what else does one need?
#10 | |||
Load netstumbler and it may give you a clue... Read pages of docs, and where possible use the same brand of equipment. |
#11 | |||
beep beep
#12 | ||
the two can not find each other (or my software is not set up right for them to connect to each other)
it's not interference, does one have to be set up as a server and one a client? if so how?
#13 | |||
beep beep
I found it was easiest to use the microsoft configuration utility for wireless networks. Go to "Network Connections" under "Control Panel" and there should be an icon saying "Wireless Network Connection" with a red X in it if it is not connecting. Double click on it, and see if you can connect to any of the networks listed in the dialog box. Otherwise click "Advanced..." and on the "Wireless Networks" tab click the "Add..." button to add information about your network. See if you can configure both systems to be the same and see if that helps. Make sure you use "Ad Hoc" for system to system communication if you don't have a Wireless Access Point.
#14 | ||
Slide Baby Slide
I've found if it's only two, use a direct network cable and a bit of changing of ya settings and bingo! Just make sure you turn your firewall off when networking then back on before you go on the net
:the_finge You want more inches...........STROKE IT!!! :the_finge Mr Super Skid-Man |
