Old 07-07-2010, 10:37 PM   #1
want-a-XY
want-a-XY's Avatar
Default erratic odometer display
hey all, on my mum's LS focus the odometer has been behaving rather erraticly in the last few days. it randomly scrolls through the entire display with various numbers and letters. the first time it happened i disconnected the battery and reset the ecu and the problem was solved. less than 24 hours later the problem reappeared, and now today the display has gone blank ie no numbers.
speedo and tacho still work fine. drives like normal. radio will not accept the code.
any ideas what's wrong with it? its going in to ford in the morning
PJ 2.5L XL Ranger - 2 3/4" Beaudesert exhaust and Hella Rallye 4000 compact's converted to HID
G6E - many mods coming soon - manual conversion
want-a-XY is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2010, 05:03 PM   #2
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: This member has made a few valuable contributions to the Forum in the Focus section, seems to know exactly what he is talking about with his posts, which are helpful and concise.
Did the dealer find the problem in the end? Sounds a little strange (and hopefully not expensive!).
2006 LX FOCUS SEDAN
Titanium Grey, factory bodykit, slightly debadged
CSA Motorvatr 17's/Kumho KU31's, Eibach Prokit/Lovells rear springs, Koni Sports Kit
Lower airbox removed, K&N Panel filter
Momo gear knob + boot + pedals, Ghia boot garnish, Zetec Chrome interior door handles
JVC KW-XR816 Headunit + more to come...
#Russ#Es# is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2010, 11:21 PM   #3
RJO89
EuroFordClub
RJO89's Avatar
I had the same problem with mine! Never found a fix for it. But I thought mine was because I had my dash pulled apart to change the LEDs. Used to flash those random numbers and letters every 72 hours or so before I'd disconnect the battery and it would fix the problem. So I would be extremely interested to see what the fix was!
'08 Black Ford Focus LT CL Hatch
Far from stock... --- SOLD :
Now riding a 2009 Kawasaki Ninja 250R :
RJO89 is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2010, 12:51 AM   #4
want-a-XY
want-a-XY's Avatar
turns out the odometer's LCD display has died. solution to the problem is an entire new cluster. $950 job including labour.
Old 11-07-2010, 04:54 PM   #5
Mick K.
Mick K.'s Avatar
The LR Focus has a reputation for needing cluster replacements. There are some UK forums where they have a few processes to try before you fork out for a new cluster, so it may save or delay your expense if you do a bit of searching on those.
MK
Mick K. is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2010, 10:30 PM   #6
want-a-XY
want-a-XY's Avatar
i would be interested in doing some research on the issue, but the 'rents aren't at all interested in cars. so me doing so is wasting my breath. i'll let you know what the bill total is when the new cluster is installed
