15-03-2008, 08:57 PM | #1 | ||
www.TUFFCARPARTS.com
Hi Guys,
Just chasing a bit of a miss in an AU2 i6 motor. Plugs and leads have been replaced with no success. Leads are quality items, and plugs are of the right heat range for the application and were gapped correctly. All I can think of now is the coilpack. The engine only has around 80k on it though, and I wouldn't have thought a coilpack would present problems so early. Does anyone know if it's common for a coilpack to go at this sort of mileage? I just want to avoid changing it unless I'm sure it's the problem, as it looks like a pain to change! As always, all advice is much appreciated! Thanks, Justin.
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
15-03-2008, 10:28 PM | #2 | ||
mine is still running like a clock at 117k`s original coil pak, perhaps the conditions play a part ,hot , dusty,humid,wet, etc, it would be interesting for some feed back at what mileages people replaced them.
15-03-2008, 10:38 PM | #3 | ||
coilpacks in the AU can go with virtually no milage on them of can last the life of the car . I actually saw one recently that was faulty out of the box so really they have no set lifespan
[SIGPIC][/SIGPIC]
15-03-2008, 10:46 PM | #4 | ||
Coilpack is a bit of a pain to change, but not too different to the coils in ELs etc. If you can borrow one for a while, I'd do that, as the coil packs aren't cheap (around the $150 mark , IIRC, though you may get one cheaper on ebay)
15-03-2008, 10:56 PM | #5 | |||
Thanks for the feedback so far guys - the one in the wagon is still going strong with 190k on the clock, so I kind of assumed this one should be ok.
15-03-2008, 11:04 PM | #6 | ||
not here much anymore
Justin a dead coilpack should log a fault code so it may be worth looking at this first
RAM 1500
15-03-2008, 11:27 PM | #7 | |||
Walking with God
According to my manual the code is P0350. Ignition Coil Failure. Possible causes Coil shorted to ground. Coil pack faulty or damaged, faulty or improper coil signal, improper signal from Crank Position Sensor (CKS) to PCM. There are other codes 0351-0354. Possible causes Fouled plugs, damaged high tension leads, incorrect plug gap, worn or damaged plugs and a few others as well. It therefore appears that if the coil pack is stuffed or playing up, but the leads and plugs are okay, then the code will be P0350. GK
16-03-2008, 12:36 AM | #8 | |||
16-03-2008, 12:37 AM | #9 | |||
From the sounds of it, it really only could be the coil, so I'll have to build up some motivation to fit a new one!
16-03-2008, 01:03 AM | #10 | |||
[SIGPIC][/SIGPIC]
19-03-2008, 01:32 PM | #11 | ||
Bit of a thread mine I guess from Page 2.
But to add to this ... I had a faulty coilpack that didn't bring up a code at all. It was an annoying miss at idle .. and under load it really showed (with a decent backfire being LPG) ... thanks goodness my intake was still in one piece. Ford wanted $300-ish for an AUII coilpack new in box ... I got one for less than $100 from a wrecker off an engine with bugger-all kays on it. Has been fine since. Mine original coilpack started playing up around the 200,000km mark.
19-03-2008, 09:30 PM | #12 | |||
19-03-2008, 09:35 PM | #13 | |||
19-03-2008, 10:01 PM | #14 | |||
[SIGPIC][/SIGPIC]
19-03-2008, 10:32 PM | #15 | ||
well i don't know how difficulty or not it is to change a coil on an el as i haven't done one before, but i didn't have much trouble at all changing the coil pack on my au from underneath....in saying that, i'd like to make a mount to move it over to the driver's side of the car near the header tank or the firewall above the exhaust manifold
19-03-2008, 11:22 PM | #16 | ||
you can check the coil pack without removing it....you can check the resistance with a multimeter its pretty easy...set your meter to ohm,s amd check for resistance between 1&6 2&5 3&4 youl find one of them will be open curcuit if theres a coil pack problem....
20-03-2008, 12:07 AM | #17 | |||
[SIGPIC][/SIGPIC]
20-03-2008, 12:21 AM | #18 | |||
Boost Addict
did it due to coilpack problems on AU they changed crank pickup ad deleted dizzy pickup for reference and redesigned coilpacks i believe there was a ef recall on coilpacks at some stage if i remember right.
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO Can't live with it, can't live without it! |
20-03-2008, 07:54 AM | #19 | |||
That's the problem I had ... had the odd missfire here and there ... even at idle ... but it was rare enough that it took a while to find the problem. Normal driving was fine.
20-03-2008, 10:11 AM | #20 | ||
Spin 'em Habib !
Mines Lasted 200Thou K's .. So I Must be on a Winner .. The only thing that me is when you go through a Carwash and the Underbody Was Gets Water in the coil pack ..
Then it sounds like a Sherman Tank
AU2PWR |
23-03-2008, 07:26 PM | #21 | ||
ive picked up a coil pack today is there any way off testing it before i put it on to see if its a goody? im hoping this will fix the miss in my engine
07-06-2010, 09:08 PM | #22 | ||
My Au2 Has Done 260 000 Km And Has Developed A Surge Under Load Most Of The Time And Occasionaly Surges When Freeway Driving Is This Possibly The Coil Pack Had New Platinum Plugs Approximately 20 000 Km Ago Still Same Leads
08-06-2010, 12:30 AM | #23 | ||
pursuit ute baby
i need to run a diagnostics on mine as well (though it seems it may not give me my answer). ive just changed my sparkies to new iridiums (xr8 pursuit) = 180 bucks, and im still getting the occasional surge etc.. o2 sensor, leads (even tho they are a/m) or coilpack is my figured culprits.
can u self diagnose without a laptop on the AUIIs ? or is it all done thru consult port? |
