Old 11-05-2010, 11:58 PM   #1
eddiemonster
Default Blind Spot Mirror
I have a 2010 Lx Focus i think i saw the side mirrors which if iam not mistaken on the xr5 turbo my question is can i buy the xr5 mirrors because they have the special mirrors for ur blind spot instead of buying those stick on ones.
If anyone can help will be appreciated
eddiemonster is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2010, 01:17 PM   #2
XR5-Boy
You mad, bro?
XR5-Boy's Avatar
Yep, the XR5 mirrors do have the blindspot section for both sides. In terms of fitting them, i'm not 100% sure. The XR5 mirrors have the indicators and heating also.
Anyone actually done this?
2009 LV Focus XR5 Turbo Performance Blue
SFS 2007 Best Cougar, SFS 2010/2011 Best Focus XR5
XR5-Boy is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2010, 09:04 PM   #3
smee323
Yes it is mine...
smee323's Avatar
If the external dimensions of the mirror are the same, then fitting should not be a problem.
In most cases the mirror part is glued onto a plastic section which is attached to the motor arm.
You should be able to remove the currently installed mirror and install the XR5 mirrors.
or
Give Athol Park Ford Spares a ring. They have a white LV XR5 wrecking at the moment
smee323 is offline   Reply With Quote Multi-Quote with this Post
