Old 13-04-2010, 03:31 PM   #1
ANZ
BLUE BLOOD
ANZ's Avatar
Default How much power to run mid - low 11
351ci
c10 std converter ATM
full spool bw diff with 4.11
in xf ute with Cal Traks
8 inch wide MT Slick
Looking for under 11.5 Qmile
How much power will i need?
ANZ is offline   Reply With Quote Multi-Quote with this Post
Old 13-04-2010, 04:39 PM   #2
xagsjoe
Patience is a virtue
xagsjoe's Avatar
450hp will do it if your car is set up well. Is it full weight? The less weight the less power you need. A forum member has a drag only XF Ute and that weighs about 3200lb with him in it and it runs around 11 flat at that weight N/A
417ci CHI headed XD.
Dynamic transmissions C4
Track times
60ft pb 1.365 (24-3-12)
10.173 @ 134.97mph 1/4
6.324 @ 108.93mph 1/8th PB
SOLD
xagsjoe is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2010, 03:11 PM   #3
dyno junkie
Not as much as you may think!
Our Monaro weighs ~3950lbs and has run 12.09 @ 113mph.
Our Territory weighs ~5000lbs and has run 11.8@ 116mph.
Weight shifted horsepower calculates ~450hp for the Monaro and ~605hp for the Territory. Both of these are in line with the recorded dyno figures for both cars.
2007 Silhouette Territory Turbo Ghia
11.8 seconds @ 116mph
Sold and bought back.
dyno junkie is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2010, 03:45 PM   #4
dyno junkie
Our Monaro also has a small stally and street gears and probably weighs a lot more than your car.
With a bigger stally and 4.11s it potentially could run as low as 11.6.
Old 05-05-2010, 11:14 PM   #5
xyute008
xyute008's Avatar
i have 475hp my best is 10.97@121mph thats in a xy ute 90/10 in front standed rear
no tramp bars on 235 et radial 5200 stall c10 4.3 gears and i spin it to 7300.
hope that helps..
xyute008 is offline   Reply With Quote Multi-Quote with this Post
