03-04-2010, 09:56 AM | #1 | ||
Hi everyone i have been on this forum for years, my first car was an au series 1 6 cyl forte. then swapped my bike for an au xr8 series 3 220kw but was under finance so had to swap back, now im about to swap my commy for a black au xr8 ute series 1 5 speed. now i know the ute has the 185kw engine so i was wondering what parts i need to make it the same as 220kw version. also he says it has svo spec heads. how do i verify this? cheers
03-04-2010, 10:45 AM | #2 | ||
i could b way off but the i thought that the only svo heads that come out of ford were on the t series 2 and they were alloy. So if the ute has a set of alloy heads i guess they could b.
IF IN DOUBT REV IT OUT |
03-04-2010, 11:16 AM | #3 | ||
well the guy selling it thinks the ute is a series 2 when its clearly a series 1. he doesnt know that much so i think he is full of ********. its a 99 xr8. series 1 fascia, cluster and front
03-04-2010, 07:55 PM | #4 | ||
not here much anymore
The intake and heads are the same throughout the XR8 series - it's just that the 220's had a little bit of work done to the heads. From memory it is injectors, intake pipework and mainly tuning that make the increased power.
2024 F150 XLT
03-04-2010, 08:06 PM | #5 | ||
Giddy up.
You'd be much better to just get a decent exhaust , CIA and tune and then drive it and enjoy.
03-04-2010, 09:55 PM | #6 | ||
ported heads,larger valves,ported intake manifold,larger throttle body,different cam,better extractors,higher fuel pressure,oil cooler,higher compression and different tune
03-04-2010, 10:48 PM | #7 | |||
Cat be Still !!!
03-04-2010, 11:13 PM | #8 | |||
Giddy up.
04-04-2010, 08:18 AM | #9 | ||
extractors were all the same on the xr8's
04-04-2010, 12:49 PM | #10 | |||
Cat be Still !!!
04-04-2010, 08:49 PM | #11 | ||
they look the same as my 185 ute, but i thought they were the same as t3 ones ,which i thought were upgraded
