Old 26-12-2009, 10:48 PM   #1
R0BD0G
R0BD0G's Avatar
Default electronic ignition?
what have people done with electronic ignition for 1300/1600 kent motors?... is there a kit? or a trick?
1628 Escort Project Thread
67.3 RWHP - Paramount Performance Dyno
DJ Automotive Tuned with proper jets
http://fordforums.com.au/showthread....4&page=1&pp=25
R0BD0G is offline   Reply With Quote Multi-Quote with this Post
Old 26-12-2009, 11:34 PM   #2
75Cortina
75Cortina's Avatar
Hi,
I'm not sure about the Kent motors Specificly, however i've used a Pertonix Ignitor Kit on my Corty before i went to a Crane Cams Hi-6 and was very impressed with it it uses a magnetic pick up so there's no contact or light diodes, it was really easy to set up and the best thing was no more points or timing adjustment =D.
This is there website: http://www.pertronix.com.au/
I think there about 120ish last time i checked,
The best thing is that you just fit it to your existing distributor and thats it, there's only 1 extra wire that connects to the Positive on your coil so it takes about 20minutes to install it all and tune it up.
Hope this helped
Jason
Current Project: Rebuilding my Corty!
220kw Au3 XR8 Engine, full Custom Zorst, EMS Computer, Underdrive pulleys and MSD coil Parks.
TKO Tremec 5 Speed
Full Floater 9in 31 Spine with locker
Its almost there!!!!
75Cortina is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2009, 11:23 AM   #3
CPOCSM
Good link there as Aldon was the distributor until they folded. The systems are the same - just a different name. I have an Aldon ignitor in the Mini and it is the bees knees(driving through driving rain, no dizzy shroud and not a hint of water shorts...it just keeps on going)
Pertronix will be a good choice...
CPOCSM is offline   Reply With Quote Multi-Quote with this Post
Old 29-12-2009, 03:18 PM   #4
shepv8
V8's for ever
Originally Posted by 75Cortina
Hi,
Hope this helped
Jason
I had a pertronix ignitor on my 2L pinto. dead easy to fit and ran like a dream. Not sure if its available for kent motors but if so , you wont regret it.
shepv8 is offline   Reply With Quote Multi-Quote with this Post
