#31 | |||||
Back to Le Frenchy
#32 | |||
JMM modded EF
Yep this is true. I have mine heat shielded using a piece of bent aluminium and some foamy/tin caoted stuff. i still wanna/going to box the pod in tho using the current intake. this prevents most of the hot air. i also heard that unless the pod is the type that uses an oil coating (not sure of finer details) it is legal to have it exposed. in QLD anyways.
edit: i aslo live in a country town so traffic lights/excessive traffic are non existant. Cheers Craig
"She goes like a zirtek" WANT A FAST FORD RING THIS BLOKE V V Abbott Engines for HeadWork 20 years experience PH Rob on (07) 5526 3883
#33 | |||
low wagooon
I have been defected for having an un enclosed pod, have also knocked cars on roadworthys for having unenclosed pod filters to
Webby
S2 AU XR6 UTE |
#34 | ||
What Wheelspin?
read vicroads rules.
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw) 2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned) |
#35 | ||
What Wheelspin?
pretty sure as long as its secured. it doesnt have to be covered. your only allowed to modify ONE aspect of your intake. be it pod filter, FMIC, manifold, etc.
which is why ricers get done. BOV,FMIC,PIPING,POD. more than one thing. this is for victoria.
#36 | ||
OzEcruisers PRESIDENT
![]() Join Date: Mar 2005
Yeah it something like that
You can have an intercooler or pod but not both ![]() And yeah an intercooler only legal if you dont cut the body to fit it
1994 Ford Fairmont EF NA 6cyl Man 3.9 diff Sedan PROEF 13.46 @ 105.78mph Tuned by DYNOMOTIVE 200BUX - AFF Drag Nats 2019 EF Wagon
#37 | ||||
Back to Le Frenchy
Interestingly I've found that the 100mm rule for underbody height isn't exactly so.
#38 | ||
I build your wish list...
3/4 bump stop travel is the over rule
#39 | ||||
Back to Le Frenchy
#40 | ||
What Wheelspin?
3/4 manufacturers original suspension travel.
#41 | ||||
Back to Le Frenchy
As for ground clearance "The ground clearanceof a vehicle measured from a horizontal road surface to any point on the underside of the vehicle except the tyres, wheels, wheel hubs and brake backing plates shall, with the vehicle in its loaded state as specified by the manufacturer be not less than:
#43 | |||
Back to Le Frenchy
Here it is
#45 | ||||
Back to Le Frenchy
Handy for me!
#46 | ||
Petro-sexual
See now thats probably why I have always misread it. That is just stupid to allow the car to be lower in the middle than it can be right next to the wheel.
I get 93mm clearance required in the middle for an EL. |
#47 | |||
What Wheelspin?
