How much would it cost to change the cluster from the base one to the sports one???
PM me if you want
depends how much you can buy a sports one for ($50 -$100), and all you really have to do is change the oil pressure sender to a output one (about $50 i think), maybe add a few wires.
that easy?
PM me if you want
To the best of knowledge, someone will confirm 100% the details, try do a search in the word 'cluster' in e-series chat to learn more.
![]() Join Date: Aug 2005
As dellboy says, oil pressure sender and a wire for the Tachometer. There isnt one from standard. I think there is already a place in the connector under the bonnet on the passengers side for it? runs to the coil.
I am about to add one of these myself. Juat make sure the cluster is out of a late enough vehicle to match yours? ![]() |
ok great, thanks mate
now with 3.73 lsd
i think eb onwards got the tacho wire as part of the factory loom
anyway check to see if u got i think a pink/ blue wire behind the dash Last edited by 5speedeb; 23-08-2005 at 08:29 PM. Reason: typo |
Mr Forty Seven
Yeah I've got an EBII, all I did was install the cluster and had the mechanic install the oil sender unit and it worked fine, you'll find without the oil sender unit the oil gauge will report either empty or full, cos on the standard cluster the light is either on or off, like a binary switch. It's a very nice upgrade and if I can do it I'm sure you can too
EFII Fairmont Ghia Fully Optioned In White XR Kit, Engine & Springs. Leather & Sunroof Also Featuring NFERNO Registration Plates ELXR Front Bar & Bonnet with Sequential Scoop 18x8 Graphite Rims, Genie Extractors and Exhaust, Chrome Moulds ELGT Steering Wheel, Clear Repeators, Cornering Lamps, Tinted Windows Walnut Highlights, Pionner DEH-P9650MP Headunit & Pro-Series Speakers Local Playground: Brisbane CBD and surrounding suburbs |
