Old 20-09-2009, 11:17 AM   #1
REDAUXR6II
REDAUXR6II's Avatar
Default AU ECU question
Hello All,
What parts of the car does the AU ECU control?
Does it control the entire car and link into the BEM, Aircon, and intsrument cluster or does it only look after the engine.
I am trying to figure out if i could run 2 different ECU's in 1 car
REDAUXR6II is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2009, 11:25 AM   #2
StealthAu
What are you plans? what are you trying to do?
StealthAu is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2009, 11:31 AM   #3
REDAUXR6II
REDAUXR6II's Avatar
well basically trying the BA\BF XR6 turbo engine option, i have covered off all areas except the AU ECU area.
so far i can get the engine in and running from the BA/BF ECU, but I need to findout what is controlled from the AU ECU and whether things like the BEM, cluster and aircon etc rely on the AU ECU to be present.
I also need to find out if the ECU needs to be present whether or not you can disable the engine features in the ECU to allow it to still run things like the Cluster, BEM and aircon etc.
does anyone have a pinout from the AU ECU that I can have a look at to help me along the way.
Old 20-09-2009, 11:38 AM   #4
REDAUXR6II
REDAUXR6II's Avatar
well i have managed to find a diagram thanks to RUSS, it looks like the BEM controls pretty much everything in the AU and the ECU hangs off that.
http://www.fordforums.com.au/photos/...hp?photo=55065
Can you get into the BEM and disable the EEC V module? which I am assuming controls the engine?
Old 20-09-2009, 02:41 PM   #5
REDAUXR6II
REDAUXR6II's Avatar
The Second option which is completely different but would an ls1 fit into an AU engine bay?
I am looking to start building something completely different to what people normally do.
Old 25-09-2009, 09:17 AM   #6
xrford
WAGONE
xrford's Avatar
good luck seems like some sweat and tears in the months to come
xrford is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2009, 09:19 AM   #7
RG
Back to Le Frenchy
RG's Avatar
CAT600 is running TerminatorS off an AU ECU so crazy can be done with them.
Old 25-09-2009, 10:38 AM   #8
frd906
why would you put a holden engine into a ford for, what are you thinking,
Welder/Fabricator at Beaudesert Exhuast
Posted by Xcabbi, Does it slap or rattle? Rattle is more to do with timing chains and tensioners. Slap is more to do with lifters, rings, bearings or GENIII boat anchors
frd906 is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2009, 01:25 PM   #9
REDAUXR6II
REDAUXR6II's Avatar
I knew this would stir the pot, i have completely moved away from the LS1 due to engineering problems, so te BA engine is on its way, i am working with herrod for the wiring and the flash for the ECU everything else is sorted, just need the parts now.
Old 25-09-2009, 02:48 PM   #10
frd906
if you were going to go v8 why not a ford v8
Old 25-09-2009, 02:55 PM   #11
REDAUXR6II
REDAUXR6II's Avatar
at this point there isn't any reason why not, but the B series engine conversion would be more interesting
Old 25-09-2009, 03:11 PM   #12
POELWYK
Lost Boost Gained Class
POELWYK's Avatar
mate good luck with this ill be watching out for this!
(i was thinking of putting a BA or BF XR6 turbo Moter into my au but thats just me thinking atm i have heaps of other stuff to deal with b4 i think along them lines)
2006 BF Fairmont Ghia
2001 AU Falcon
POELWYK is offline   Reply With Quote Multi-Quote with this Post
