Old 09-08-2009, 01:28 PM   #1
kcej
2mny projects 2 lttl time
Default AU3 BEM replacement....retrain or not?
If I replace the faulty BEM in my AU3 wagon with a known good one, will I need to.....
1. Do nothing to retrain it to my key?
2. Go through a retrain process (switch it on for an hour till the door locks cycle, etc., etc.) ?
3. Take it to a Ford dealer to get it retrained to be compatible with my ECU, Keys, etc.?
kcej is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2009, 04:20 PM   #2
kcej
Default Help
Anyone done this before?
Surely someone has had their BEM crash and knows the answer??
Thanks Keith
Old 12-08-2009, 07:29 PM   #3
JC
Miami Pilot
JC's Avatar
I've only ever changed an ECU (not BEM) in an EF Fairmont; for that one, i didn't have to do anything special; it worked out of the box.
OK, so that doesn't help for an AU, probably, unless it's an AU1 using smartlock (maybe).
The usual advice with this swap is do 3, but if you don't need the car for a few days, maybe swap it over and try 1, and then 2 if 1 doesn't work, and then do 3 if 2 doesn't work (and make sure to post up your results).
Ford Performance Club ACT
Old 12-08-2009, 08:22 PM   #4
smally289
growing up is optional
smally289's Avatar
Ive had fun with these before ..... http://www.fordforums.com.au/showthread.php?t=11223017
smally289 is offline   Reply With Quote Multi-Quote with this Post
Old 14-08-2009, 12:40 AM   #5
kcej
Default Thanks
Thanks guys....will try to get it going this weekend, and as soon as I have, WILL post results
Thanks again, Keith
Old 18-08-2009, 12:36 PM   #6
kcej
Default Results.... BEM replacement
Just remembered a nephew is an ex-Ford mechanic so I asked him
Says it needs to go to Ford to be retrained to my keys, but good news is its only about $80 (plus towing of course)
Being a bit tight with money, I'll fit it myself and try the self-retrain before I spend the money, and will update the thread with my results either way.
Cheers Keith
Old 24-09-2009, 10:55 AM   #7
67fasty
How did you go? I've got a similar problem as at this morning. Keen for a cheap/quick fix rather than towing the car to the dealer! :
67fasty is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2009, 03:05 PM   #8
Ride
Stay Classy ™
Ride's Avatar
AFAIK its a dealer job, there's a unique key # programmed into both the BEM and the ECU, if these don't match then the BEM will shut you out. The idea behind it is for anti theft so that you can't use an engine from a stolen car and its ECU to run. Also you will need all sets of keys + fobs when you do get it re-programmed.
Ride is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2009, 10:08 PM   #9
hsv.eta
So just to make sure I have understood all these (bloody AU is may more complicated than my old XH) In order to fit a new ECU one would need the ignition (including two keys), BEM, and ECU from the same car, otherwise its off to ford to have it reprogramed (if installing a new ECU with the original ignition and BEM).
1983 Bahama Biege XE S pac manual.
2006 Octane BF XR6 Turbo Sedan
2005 White Courier Dual Cab
hsv.eta is offline   Reply With Quote Multi-Quote with this Post
Old 24-09-2009, 11:20 PM   #10
Ride
Stay Classy ™
Ride's Avatar
That would be correct, I enquired about this when I first considered swapping the motor out, spoke to a friend who works in Ford service and a tuning shop, both said the same thing.
